LS6 intake with EGR ... What are the different designs?
What is different with taht design and the LS1Speed version?
Are there others?
Here's the link, but I noticed that they've jacked the price up to $108 now <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
http://www.lingenfelter.com/lingenfe...0&dept%5Fid=16
I drilled out the intake with a 1.25" hole saw drill bit. I then took a file, and smoothed out the hole, washed it, then blew it out with my compressor.
I then prepared both surfaces of the EGR adaptor and the socket that the adaptor slides into on the intake with my dremel and a sanding drum on it by roughing up the surfaces a little and once again blowing it out with my compressor.
I then got out the JB Weld indrustio weld, mixed my gooey concoction and spread liberally on both the surfaces of the EGR adaptor and the walls of the socket on the intake where it slides into.
I then proceeded to pound it in (as it did fit snug already) with the butt of a screwdriver until it was perfectly sealed against the base of the intake where it sits on. I then let it dry, harden, and seal for two days with the first 4-5 hours under my hot halogen light.
When I reconnected the EGR on the car itself, I still used the rubber o-ring. It was tough to tighten down but that friggin intake will snap or crack itself before that seal is broken or that adaptor comes out. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>Hmmmm....there's $110 towards the cost of LS1 edit to just do an EGR delete....</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why delete it? I contemplated deleting mine before drilling into the intake. But the EGR smooths out light to mid throttle application soo much, I decided to keep it. After re-installing everything, power delivery is smooth and linear and without coarseness that could be an issue with a removed EGR.
Also, here in Illinois they just recently changed the emissions test for OBDII vehicles. Instead of doing the IM240 roller test, they now plug into your data port under the dash, scan for DTC's and check that all operating parameters in your PCM are still active. Turning off the EGR in the PCM if subjected to this test, could raise a red flag.
<small>[ August 28, 2002, 11:56 AM: Message edited by: CMNTMXR57 ]</small>
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dave Carney:
Also, here in Illinois they just recently changed the emissions test for OBDII vehicles. Instead of doing the IM240 roller test, they now plug into your data port under the dash, scan for DTC's and check that all operating parameters in your PCM are still active. Turning off the EGR in the PCM if subjected to this test, could raise a red flag.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So why are the 2001-2002's so smooth in mid throttle without the EGR?
I wasn't saying that the non EGR LS6 wasn't smooth, just that when the EGR is doing it's job makes it an even smoother transition.
As an FYI, I had Ed Wrong do my original PCM tuning. On the third attempt he turned off my EGR even though I told him I DIDN'T have an LS6 intake installed yet. Needless to say, with the EGR turned off, it ran like sh*t and I suffered a sh*tload of KR at throttle tip on because of it.
<strong>Hmmmm....there's $110 towards the cost of LS1 edit to just do an EGR delete....</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">As I understand it, LS1edit just blocks the EGR failure SES light from illuminating. It still sets a hard code in the PCM.
While it doesn't appear to hinder performance, it will red flag an emissions test.
On another note, what intake, LS1 or LS6 any year, came with 2 bolts for the EGR? I've been asking for a while, no one knows
<small>[ August 29, 2002, 03:47 PM: Message edited by: Viper ]</small>
