What will a BAD O2 cause the car to do?
so would a bad 02 cause my car to act up under acceleration like its getting way to much gas or something?
<strong>Yes, a slow switching O2 will play havoc with the A/F mixture control and most likely cause you to go rich which will cause the stumble/hesistation. Smell any unburnt fuel from the exhaust ?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thats something else i just thought of, but I did notice the exhaust smelling a little gasy. It wasnt the same cam smell i had been smelling. I just thought maybe the intake had a break in smell lol <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
question is, how do i find which one it is?
I have rear o2 simms but i got a 0131 SES light(i think that was the number)
i know when i was changing the plugs i hit a sensor on the drivers side towards the very front of the manifold. Actually bent it a little
Circuit Description:
The PCM supplies a voltage of about 450 mV between the HO2S high and low signal circuits. The oxygen sensor varies the voltage over a range from about 1,000 mV when the exhaust is rich, down through about 10 mV when the exhaust is lean.
The PCM monitors and stores the heated oxygen sensor (HO2S) voltage information. The PCM evaluates the HO2S voltage samples in order to determine the amount of time the HO2S voltage was out of range. The PCM compares the stored HO2S voltage samples taken within each sample period and determines if majority of the samples are out of the operating range.
The PCM monitors the HO2S voltage for being fixed below a predetermined voltage. If the PCM detects the voltage is below a predetermined voltage, this DTC sets.
*The PCM sets this DTC when the vehicle runs out of fuel.
*Heated Oxygen Sensor (HO2S) wire: Sensor pigtail may be in contact with the exhaust manifold or the exhaust system.
*An oxygen supply inside the HO2S is necessary for proper operation. The HO2S wires provide the supply of oxygen. Inspect the HO2S wires and connections for breaks or contamination.
*Inspect for an intermittent ground in the signal wire between the connector and the sensor.
*Lean injector(s)
*Fuel contamination: Water near the in-tank fuel pump inlet can be delivered to the injectors.
*Fuel pressure: System will be lean if fuel pressure is low.
*Exhaust leaks: An exhaust leak near the HO2S can cause a lean condition. Refer to Exhaust Leakage in Exhaust System.
*Vacuum or crankcase leaks can cause a lean condition.
*If the above are OK, the HO2S may be at fault.
Well, this is pretty much all the possible causes, but like Battmobile stated, chances are it's f#&@^! up from being bent. The wiring is apparently sensitive also - it provides an oxygen supply to the sensor. Good luck!
<strong>It is your front driver O2 sensor. I broke mine when I was taking my Y-pipe off. A bolt was frozen where the pipe mates to the manifold. Like an idiot, I banged on the bolt hard, not thinking that the fragile sensor was plugged in right behind there. My car stumbles some and runs rich (can smell it) just like yours. Got the same code. I'll fix it tomorrow.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">now that i think about it.. about 1 month ago i had the same prob coming from a stop light. The car stumbled like it was about to cut off from running rich. Then it cleared up. Maybe it finally just went bad. Oh well, ill swap out the sucker for a new one this weekend or the first of the week. Im beting that was my problem..... shew im so paranoid now about everything breaking <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
after a 918 gives way then you freak out about every small thing
<img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
<strong>mine did that once...cleared itself up afterwards...it ran like dogsh%t when it was doing it...exactly like you are describing...like it was loading up with fuel LOL</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thats the thing lol.. when i went out the car was fine for like `10 mins.. came to a stop and backed up, then pulled ahead and the car started crapping out lol <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
once i finally got moving the car seemed fine. First thing that came to mind was SPRING BREAKING!! lol but when she ran fine from 40+ i ruled that out. Gotta be a crappy 02 then
