help
Old Apr 10, 2006 | 09:54 PM
1MEANGTO's Avatar
Default help
has anybody gotten something loose after using lock-tite???? ive tried everything nothing will loosen, any suggestion??
Old Apr 10, 2006 | 09:59 PM
deviate42's Avatar
what are you trying to loosen?
i just use some liquid wrench. hose down the area and comeback in 10 mins, usually works fine
Old Apr 10, 2006 | 10:02 PM
camaroextra's Avatar
use a torch on it if you can, lock-tite will melt
Old Apr 10, 2006 | 10:07 PM
1MEANGTO's Avatar
fuel selaniod, for n20,, on the wifes car, took the torch to it once, told her to go get the fire extinguisher just in case hahahaha
Old Apr 10, 2006 | 10:08 PM
TheBlurLS1's Avatar
That's what she said...
I try not to use loctite on anything besides steel-steel. When i HAVE to loctite something (cam bolts, throttle body blade), I use the blue loctite. That red loctite is some bad **** guys. When you use red loctite on a bolt over 1/2" or so, you need the national guard to bust it loose.
Old Apr 10, 2006 | 10:33 PM
well im not responsible when you burn something down
Old Apr 10, 2006 | 10:34 PM
1MEANGTO's Avatar
hehee, its off!!!!
hahah yeah, have you taken your back seats out yet? have fun with that!
Old Apr 10, 2006 | 10:41 PM
TheBlurLS1's Avatar
Sweet! I'll have an excuse to get out "The Negotiator".
That's the name given to my breaker bar. It ****** sneezes at crank bolts.....
Old Apr 10, 2006 | 10:44 PM
yeah have fun stripping the snot out of those torx heads. i used some gnarley vice grips to finish them of and that did the trick
