Throttle Body Water Bypass worth $17?
If it does give you 4 hp, then it's a pretty cost-effective gain, if you ask me.
Be advised, the fitting on the radiator is larger than the fitting on the coolant tube connecting the heads. I suggest you get one that fits the smaller tube, decently, then force the other end over the radiator fitting. You might actually have to carve out the inside a bit with a knife.
You can yank those tubes OUT of the throttle body. It cleans up the appearance a little bit and allows a little more room to run your hose.
There's a small lip you can drive a screwdriver or something under to get them moving out a little bit. That lip is what keeps them from being pressed into the throttle body too far. I've done this to 2 different ones. They are pressed in, and WILL come out if you keep after it.
The first one i did, i think i put the tubes in the vice, then turned/twisted/pulled like hell untill they popped out.
And NO I don't beleive it is worth any real HP either. BMR's test results are flawed BIG time as they actually record more HP with the HIGHEST air intake temps, so it totally goes against what they are trying to say. Plus a rolling road dyno is not accurate enough (or not operated accuratley enough) to make such conclusions on such small increases. +- 15rwhp is possible with out any changes to the vehicle over 5-6 dyno pulls, and it can and does vary which pulls record the highest numbers.
Also I don't beleive the coolant exists to prevent freezing as there are hundreds of other cars out there that don't have coolant thru the TB yet never have issues with freezing. I believe this is just a myth, folk law or make believe.
IMO the coolant is there to promote better cruise economy, warmer air is less dense so performance will suffer but mpg will improve. However the TB is only very small and the itake manifold plastic and not metal, so in order for it to significantly affect the air intake temps the air will have to move slowly thru it, such as 55-70mph in top gear. A 2.73 geared auto will only be spinning over at like 1500rpm with the TB blade almost shut so the intake air speed is comparitivly low. However at WOT or near WOT conditions the intake air speed is very fast and I seriusly doubt that it remains in the hot environment long enough to have any significant affect on intake air temps.
Personally the only time I would perform this mod is if I purchased an aftermarket TB which didn't cater for it.
FYI.....they didn't do it for performance or fuel economy reasons.
The reason they did it was for EMISSIONS....especially at cold start.
They've been doing this for a looooong time. On the 3rd gen cars (other than TPI), they have a switch that opens up to pull hot air off the exhaust manifolds when the car is cold. They've done it for a long time on many other vehicles to.
The exhaust manifolds will heat up very quickly (less than a minute I would imagine) even when cold outside and will radiate heat, and yes you are correct many cars have an intake over the exhaust manifold to draw in hot air for this very reason.
But it may take a TB 5 mins maybe even 10 mins before it will actually be at a high enough temp and by that time the engine will have finished it's cold start cycle.
