EGR block-off? what's wrong??
Old Sep 14, 2002 | 11:02 AM
TK 14 SS's Avatar
Default EGR block-off? what's wrong??
I'm in the midst of doing the cam and headers and was about to put on the EGR blockoff plate when I realize that it (and the gasket) is too small to cover the "hole".
Am I not seeing this right, or am I doing something wrong?
Troy
BTW...I just removed the EGR from the manifold (and the car entirely)
Old Sep 14, 2002 | 11:17 AM
sited12's Avatar
Default Re: EGR block-off? what's wrong??
Are you confusing the EGR with the AIR holes. Or did you get the block off for the AIR and want the EGR one?
Old Sep 14, 2002 | 03:03 PM
buschman's Avatar
Try going to Pep Boys and picking up a $3 1 3/8" freeze expansion plug. You'll see freeze expansion plugs at a lot of places, but for some reason no one sells the 1 3/8" version except for a well stocked Pep Boys. Hope this helps.
Mike
Old Sep 14, 2002 | 06:54 PM
Z06PSI's Avatar
On the Freeze plug what do you use to bond it to the EGR hole?
Old Sep 14, 2002 | 07:24 PM
felton316's Avatar
The egr block off plate you got is for the EGR tube coming from the headers to the bottom of the EGR itself. Are you looking for a plug for the EGR hole in the intake?
Old Sep 14, 2002 | 08:31 PM
TK 14 SS's Avatar
Okay, okay, I finally figured it out and took care of it...
Here's what's going on... the other EGR plate is for on the headers <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> and then I got a 1.25 expansion plug and used it in the EGR hole on the manifold.
Thanks for the help guys! (Buschman <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> )
Troy
Old Sep 15, 2002 | 12:11 AM
TK 14 SS's Avatar
No, I'm pretty sure that I've got the right one. I ordered them from Speed Inc. I got two for the air tubes (off of the headers) and I've removed the air system entirely; and I got the one (a little larger) for the EGR. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Troy
Old Sep 15, 2002 | 12:30 AM
sited12's Avatar
What kind of headers are you putting on. I have hookers in the mail along with the same block offs from Speed Inc. So i hope i dont run into this problem also.
Old Sep 15, 2002 | 12:39 AM
TK 14 SS's Avatar
SLP LTs
I don't know <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> ... I'll figure something out
Troy
Old Sep 15, 2002 | 06:59 AM
DaddySS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TK 14 SS:
<strong>Okay, okay, I finally figured it out and took care of it...
Troy</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Good work! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 15, 2002 | 10:13 AM
98TAauto's Avatar
for the AIR and egr block offs on the headers it doesnt take a rocket sciencetist to make a little plate outta metal or alum. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
i just found some scrappy metal, sanded it down, rounded the edges, drill some holes and bolted into place. Got some gasket seal gunk from auto store and no leaks <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
glad you got it figured out though <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 15, 2002 | 02:18 PM
Z06PSI's Avatar
For the EGR hole on the intake use the 1 3/8 freeze plug with a little RTV. Worked like a charm. No more leak and it looks nice as well.
Old Sep 15, 2002 | 04:34 PM
buschman's Avatar
<strong>Thanks for the help guys! (Buschman <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> )
Troy</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No Problem Troy, glad you got it working. I would advise keeping an eye out for a 1 3/8" plug when you get the chance. By the way they specifically tell you not to use any sort of sealant, especially in that area of the engine. I'm sure a little hardened sealant getting sucked up in the intake is not gonna do good things for your enine. The plug itself seals perfectly. I'm sure the 1 1/4" will work fine, but keep an eye open, the 1 3/8"s are hard to find.
Mike
Old Sep 16, 2002 | 06:32 AM
JackZ28's Avatar
Anyone have a pic of the freeze plug? Thanks.
Old Sep 16, 2002 | 10:56 AM
Viper's Avatar
Why not buy the LS6 intake without the EGR provision from PACE? For $435 it comes with the lines and freeze plugs too, INCLUDING shipping!
