PSJ or anyone please help!!!!
Old Sep 15, 2002 | 07:01 PM
Justin99TA's Avatar
Default PSJ or anyone please help!!!!
Ok I have been fighting a random missfire now for months. I changed plugs, wires, fuel filter and still no luck, I got the idea to hool my timing light up the plug wires to see if its in the ignition system. I watched the light and listened to the exhaust and the light would skip a beat evey 10-15 secs on some clyinders. heres what I got. All the cylinders on the left bank had a miss to them. all on the right except the number 8 where fine I don't know what the hell the prob is pleas help <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Sep 15, 2002 | 09:01 PM
wrencher's Avatar
wrencher
Default Re: PSJ or anyone please help!!!!
You got any other codes (than misfires) out of pcm?
Old Sep 16, 2002 | 02:18 AM
Justin99TA's Avatar
Just for my missing 02 sim thats it I don't even have a misfire code
Old Sep 16, 2002 | 02:35 PM
Justin99TA's Avatar
I have autolights with a 038 gap it did it with the tr6s too!
Old Sep 17, 2002 | 12:27 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What plugs and plug gap are you running?
Old Sep 17, 2002 | 05:51 AM
LS1derfull's Avatar
Go over the grounds on motor, back of the heads especially.
Old Sep 17, 2002 | 09:51 AM
LS1Tech Co-Founder
.038 for nitrous? That's a pretty tight gap it's going to cause the car to run a bit more rough.
Sometimes a misfire is caused by a car running too rich at idle too... Car is basically loading up a bit. Can always take a MAF T and try to lean out the base a bit and see if it helps.
Old Sep 17, 2002 | 10:05 AM
Spydum's Avatar
Just curious, you say its only on one bank. Did you check the ignition coils out? Try swapping sides, see if the problem follows.
Old Sep 17, 2002 | 10:42 AM
CMNTMXR57's Avatar
How often is the misfire? Do you have a cam? I have a couple at idle while the engine is still warming up to operating temp. Once up to operating temp, it still misfires occasionally at idle though not as much when first running. Probably due to what PSJ said, it's running a little rich at first.
A few misfires at idle are ok, especially with h&c. Once you're on the gas, you shouldn't be getting any and that's what is really important. Idle really shouldn't be a concern unless it's soo bad that the engine doesn't idle smoothly which one every 10-15 seconds doesn't seem to be.
<small>[ September 17, 2002, 10:44 AM: Message edited by: CMNTMXR57 ]</small>
Old Sep 17, 2002 | 05:50 PM
Justin99TA's Avatar
ok im going to open up the gap and switch coils around I will keep yeah posted
Old Sep 19, 2002 | 07:29 PM
Justin99TA's Avatar
My buddy said it could be a bad MAF sensor or a stuck open EGR. ????????
Old Sep 19, 2002 | 08:39 PM
Superman's Avatar
In complete darkness while the car is running see if you can see any arching from wires/plugs/coils...
Old Sep 20, 2002 | 05:38 PM
Justin99TA's Avatar
No arching already checked that tomorrow I will check plugs and switch mafs during the Notre Dame game
