Will stock injector work on a 382 Stroker?
Old Oct 8, 2002 | 03:08 PM
ramair's Avatar
Default Will stock injector work on a 382 Stroker?
Are the stock injectors big enough for a 382 stroker? With all the bolt ons heads and X1-cam.
Old Oct 8, 2002 | 10:07 PM
02 'Hawk's Avatar
Default Re: Will stock injector work on a 382 Stroker?
if you have a 02 (isn't that when they went back to larger injectors?) or before they went smaller, then yes.
hell, 01 or 02 they went back to larger injectors...
Old Oct 8, 2002 | 10:19 PM
beardWS6's Avatar
I`m getting MTI S2 heads and X1 cam on mt LS1, I`m putting 30lb injectors because I`m going to run a 100 shot. The stock injectors are 28lb on my 2001 WS6. They can handle around (450RWHP Safely) anymore and you are pushing it. Better to be safe than sorry, also I`m getting a T-Rex fuel pump. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 10, 2002 | 04:31 PM
ramair's Avatar
I have a 99 T/A I don't know exactly what lbs injectors it came with I was under the impresion is came with 24lbs.
Old Oct 10, 2002 | 05:04 PM
383ss's Avatar
I've still got stock injectors <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
but I need to upgrade.
Old Oct 10, 2002 | 05:16 PM
BADZ's Avatar
Moderator
98,01,02 are 28lb inj. with that size ci eng, I would go with at least a 36lb IMO.
Old Oct 10, 2002 | 05:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
With a 382ci stroker I would at least run a 30lb injector. Sure a 98 injector can be maxed out to handle it, but at what, 110% duty cycle? You are not supposed to run injectors at full duty cycle they get overworked and HOT.
Old Oct 11, 2002 | 11:23 AM
ramair's Avatar
I saw that on the list 98,01& 02 are 28lbs so in 99 they? Are they 24lbs for 99?
Old Oct 11, 2002 | 02:26 PM
ak motorsports's Avatar
'98,'01''02= 28.6# inj.
'99,'00=26.8#inj
Old Oct 11, 2002 | 03:06 PM
ramair's Avatar
Thanks a lot for the info gye's looks like I'll be changing injectors this weekend. I have an intake from a 98 T/A with injectors and all laying in my room.
Old Oct 11, 2002 | 03:24 PM
ramair's Avatar
Are the injector lbs # on the injector them selfs? How can u tell other then what year model they came off of?
Old Oct 11, 2002 | 04:37 PM
LeadFoot2's Avatar
I'm probably wrong on this as it looks like ak motorsports has more exact numbers, but I thought I had read a while back (in late 1999 maybe) that the 98's had 24# injectors and the 99's had 22# injectors.
Don't know about the 00's and later.
But like I said, I'm probably wrong...
Old Oct 11, 2002 | 05:01 PM
P&DZs's Avatar
I've still got the stock 2000 injectors in the 382 but I'm built mild and the car is purely a street toy without any aspirations of being the big dog on the block. Enjoying the instant torque in day in day out use is a pleasure. Could depend on how far you intend to go.
Old Oct 14, 2002 | 03:26 PM
ramair's Avatar
Is there any other way of telling what lbs the injectors are like a # on them or something?
