Weiand and BBK Intake Owners IN HERE
My second question is I am a nitrous car, so with the cold charge (-129.7*F) i should actually cool down the metal of the intake right?
I am considering the weiand and your imput will be greatly helpful. I'm on my third LS6 now Back fire blew the 1st I dropped the 2nd the one I have currently (1 month) is discolored and looking brittle on the support coloum inside.
Thanks for any information you have to offer. ~Derek
Think about about the volume of air and the speed as it passes through the intake. Plus you can port match the intake ports to the cylinder head.
I actually felt a slight boost in low/mid range torque when I swapped for the Weiand. No difference up top. It still pulls like a raped ape. I have 420 rwhp N/A currently.
I'd recommend the Weiand! If I had the choice I'd do it again in a heartbeat. I don't know about the BBK design, and honestly there aren't many who have it.
Plus they dropped the prices on the Weiand manifolds now. They used to be $8xx for polished and now it's $5xx. I traded my stock LS6 for a new satin Weiand and polished it myself. (not recommended.)
Thats good i was wanting it for its strenght if it possibly didn't loose that much hp, but I can live with a gain down low
You can port match as large as you want... I simply made the walls glass smooth, I didn't have the time (I'd already spent 3 weeks polishing the outside and 2 months on the rest of the motor, I wanted to drive the b!tch)
When I add the Procharger/different cam later this year I'll probably port match the intake.
I will tell you that the intake is a 35 pound pig. You will not be hurting it with a nitrous backfire. Oh yeah, I had to make my own egr block-off plate. (trianglar) When I got my manifold they weren't yet made by the company.
Here's a close-up of the egr plate. Thin 1/8" aluminum plate with one hole drilled for the hold down.
The heat soak has me baffled as well, they may have a SLIGHT advantage unless you are ROAD RACING for like who knows how long. How much power does an LT1 lose?
http://www.professional-products.com...oldsLS1LS2.php
I bought the same manifold. Did the stock fuel rail assemble fit over or did you have to change or modify?
In the stickeys there are also comparisons. The author states that he belives the limit of the Weiand is the inlet diameter. It can be bored to about 81mm without much effort. It's never gonna get to 90mm, but, I'd say there are gains @ 81mm w/ port matched runners.
Plus it looks great when polished!!!
If I had to do it again, I wouldv'e just bought it polished and then "brightened" up the shine.
Thanks for the compliments.
~Joshua
