LS6 intake results not good!
Old Oct 31, 2002 | 07:28 AM
Larry's Avatar
Default LS6 intake results not good!
I installed an LS6 intake on my car and the results show I gained nothing. Apparently even lost a little.
Two weeks ago I ran an 11.978 @ 112.74 mph. Installed the LS6 intake, last night ran a 12.065 @ 112.63 mph. The weather conditions were almost identical. Both runs the temperature was 66 degrees. Humidity last night was up to 78% verses 60% and the barometer was up to 30.06 verses 29.95.
I am wondering if I bought a standard intake. It has mold number 12573572 molded on the manifold. Is this really an LS6 intake?
I have an LS6 cam and ported heads so surely I should have gained something. My heads are self ported but they were dynoed to gain 20 hp so they do flow better than stock heads.
Old Oct 31, 2002 | 07:36 AM
JoSeY's Avatar
Default Re: LS6 intake results not good!
Larry, was the bottom of the intake FLAT? That is the most surefire way to tell...the LS1 intakes are concave on the bottom allowing the coolant line to run beneath it where as the LS6 is flat requireing you to go to the 2 seperate coolant lines....
Old Oct 31, 2002 | 07:41 AM
99taws6's Avatar
What were your short times like on both runs? That could be the difference, also has your tuning changed with the addition of the intake?
Old Oct 31, 2002 | 09:04 AM
Larry's Avatar
JoSeY,
The bottom of my new intake is flat. I looked it over real good before installing it and this is about the only difference I could see. I did use the plugs and coolant bypass tube.
99taws6,
Last night: 60' 1.675, 1/8 7.692 @ 90.10 mph.
Oct 16: 60' 1.659, 1/8 7.713 @ 90.19 mph
There has been no programming since the install. I had about 60 miles on the car with the new intake.
Old Oct 31, 2002 | 09:46 AM
BLUEBYU's Avatar
More time for the pcm to adjust the base tuning....that was my experience. I had to richen up 3 times before it settled.
Old Oct 31, 2002 | 10:40 AM
Larry's Avatar
Can anybody verify that this 12573572 number is really an LS6 intake?
I ran a search but found nothing about this part number.
Old Oct 31, 2002 | 02:36 PM
DONAIMIAN's Avatar
it will take around a couple of hundred miles to realize a difference bacause the computer has to get use to more air flow. it should be straightned out after 500 miles. You live in sugar land so just come into town an run it around 610 a couple of times. Instant 500 miles <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> but anyway where did you get it from
Old Oct 31, 2002 | 02:47 PM
Larry's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stang killer:
<strong>it will take around a couple of hundred miles to realize a difference bacause the computer has to get use to more air flow. it should be straightned out after 500 miles. You live in sugar land so just come into town an run it around 610 a couple of times. Instant 500 miles <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> but anyway where did you get it from</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">500 miles! My car is a 98 and it only has 12K miles. It will take me months to clock up 500 miles.
I bought it off of Ebay. It is new and never installed and was sold as an LS6 intake.
Surely somebody can identify that number?
Old Oct 31, 2002 | 03:13 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Well 12573572 is not a current GM part number. Not sure what you got, but I tend to think it is an LS1 intake. That is why I never buy off ebay <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Oct 31, 2002 | 09:20 PM
DrkPhx's Avatar
I have both intakes in the garage and it's neither one. GM did change the #, so it could be an older one.
BTW- Where did you get it from; Miami Motorsports?
Old Oct 31, 2002 | 09:29 PM
98UltraZ's Avatar
What about Miami Motorsports?!?!? I just ordered a part from there.........
Old Oct 31, 2002 | 09:47 PM
Larry's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BLKTA:
<strong>I have both intakes in the garage and it's neither one. GM did change the #, so it could be an older one.
BTW- Where did you get it from; Miami Motorsports?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I bought it from an individual but the box said it originally came from Speed Inc. out of Illinois.
Old Oct 31, 2002 | 10:27 PM
770Guy's Avatar
If the bottom of the intake is flat then its an LS6 intake. I know that for sure. because the LS1 intake has a valley for tubes to run underneath it, you gotta drive it more so the PCM can get used to it.
Old Nov 1, 2002 | 06:42 AM
pekkaz's Avatar
Can somebody give more details on what usually happens with tuning ? What's the effect with different loads and rpms.
Old Nov 1, 2002 | 07:12 AM
Larry's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 770boy:
<strong>If the bottom of the intake is flat then its an LS6 intake. I know that for sure. because the LS1 intake has a valley for tubes to run underneath it, you gotta drive it more so the PCM can get used to it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I will give it a few more miles and then see what happens at the track. Sure would like to know what that part number really is first.
Old Nov 1, 2002 | 07:17 AM
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
Don't you think he bought the LS6 intake in that box, put his stock LS1 intake in their and sold it?
Old Nov 1, 2002 | 07:53 AM
Larry's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Joe D:
<strong>Don't you think he bought the LS6 intake in that box, put his stock LS1 intake in their and sold it?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's why I am trying to find out about the number 12573572. That number is molded into the manifold. He didn't change that.
The manifold is flat on the bototm and some have said that only LS6 manifolds are flat. I still didn't gain any et though!
Old Nov 1, 2002 | 08:32 AM
Shaner's Avatar
I just pulled mine out of the box and I have the same part number on my LS6 intake.
Old Nov 1, 2002 | 08:45 AM
onfire's Avatar
Coal Mining Director
If the bottom is flat it has to be a ls6 intake. That's how they increased the plenum area. All ls1's have the double hump bottom.
Old Nov 1, 2002 | 09:29 AM
Larry's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Shaner:
<strong>I just pulled mine out of the box and I have the same part number on my LS6 intake.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's what I needed to know. I suppose I do have an LS6 intake. Is the part number an 88890524 on the box?
Now to find out why I lost et. As some have said, I may have tuning issues to deal with now.
Thanks!
