MAF ends causing rev limiter problems?
Old Nov 11, 2002 | 08:46 PM
Ryan23silverado's Avatar
Default MAF ends causing rev limiter problems?
Has anyone heard of aftermarket MAF ends causing rev limiter problems? It hits rev limiter (set at 6500 on an LS1) in the 2-3 shift pretty badly before it shifts. I have reprogrammed the computer to settings where it should not have this problem, but it continues. I have heard that aftermarket maf ends could change engine characteristics that may cause something like this. Any ideas??? TIA Ryan
Old Nov 11, 2002 | 10:05 PM
WILWAXU's Avatar
Default Re: MAF ends causing rev limiter problems?
Nope. Never seen that.
Old Nov 11, 2002 | 10:50 PM
ZYouL8R's Avatar
Yes that can happen. After market MAF's on A4's reduce inline pressure and can definitely effect shifting.
Old Nov 12, 2002 | 01:26 AM
Thanks for the replies.
ZYouL8R - do you know how it reduces inline pressure? It seems strange that an intake component would affect something like that, but that is what several techs have told me.
I will put the stock ends back on to see if it will cure this problem
<small>[ November 12, 2002, 01:27 AM: Message edited by: Ryan23silverado ]</small>
Old Nov 12, 2002 | 03:45 AM
98NBMSS's Avatar
if that doesn't fix your problem try checking your tranny fluid. That will cause you to hit the limiter
Old Nov 12, 2002 | 06:37 AM
unit213's Avatar
Administrator
ZYouL8R is right. My A4 does the same thing. It does it periodically though. Not sure exactly how it reduces pressure.
Old Nov 12, 2002 | 09:33 AM
WILWAXU's Avatar
I've seen cars do the exact same thing completely stock.
My 99 SS would hit the limiter if ran it in D instead of OD.
If the car is hitting the limiter... then check the fluid level with the engine running. If that's ok, then raise the limiter.
Lastly, if you think it's the MAF ends... there easy to "uninstall" to check your theory.
<small>[ November 12, 2002, 09:42 AM: Message edited by: WILWAXU ]</small>
Old Nov 12, 2002 | 09:36 AM
unit213's Avatar
Administrator
WILWAXU
Do you think stock internals can handle a higher rev limiter?
Old Nov 12, 2002 | 09:47 AM
WILWAXU's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by camaro_ls1:
<strong>WILWAXU
Do you think stock internals can handle a higher rev limiter?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hehe.. I've proven that it can handle 6600 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Anything above that, I wouldn't recommend.. but my car use to live between 6200-6600 at the track due to my UT-4600 converter. I now have a more 'sane' TP-4200.
BTW: This car is my daily driver, and was my only car till 6 months ago.
<small>[ November 12, 2002, 09:48 AM: Message edited by: WILWAXU ]</small>
Old Nov 12, 2002 | 09:53 AM
F8L Z71's Avatar
12 Second Truck Club
YES!
Has happened to me. Thiswas before anyone knew that it was the MAF ends causing it so I put up with it for like 8 months... <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Took em off and PRESTO! perfect shifts. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Nov 12, 2002 | 10:12 AM
unit213's Avatar
Administrator
Will the increased rev limiter make any more power with a stock converter?
Old Nov 12, 2002 | 01:15 PM
camaro98z28's Avatar
Thanks Ryan. I will install the Stock MAF ends on today and I am having the Trans Fluid Changed today also.. Thanks Jeff <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
