ASP Pulley bolt questions
My question is: I know ASP supplied me with a new crank bolt which I used in installing the pulleys - but now that those are coming off, can I reuse the stock bolt that I pulled with the stock pulleys (I kept it all) or do I need to order a new one.
And once I get the car back and put the ASP's back on - can I reuse the bolt that came with the ASP's (on the car now) or do I need to reorder a new one?
Anyone know a part number by chance?
Thanks.
Good luck!
Dane
<strong>Why is it necessary to buy a new bolt?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The crank bolt IS a torque to yield bolt same as what comes on the cylinder heads from the factory. The bolt is designed to have a certain amount of "stretch" as you tighten it to retain pressure on the balancer. Think of it as sort of a rubber band, a really really strong rubber band. If you reuse a crank balancer bolt retightening it will stretch it beyond what its designed to stretch and possibly to the point of failure. This is why the old bolt is used to initally tighten the crank balancer then install a new bolt to specs so that you don't stretch the new bolt beyond its limits.
Jay
<small>[ November 12, 2002, 01:48 AM: Message edited by: JAY4SPEED ]</small>
So it is VERY necessary IMO to remove everything and return the car to stock condition as I dont want to give the dealer ANY reason to balk at the repair.
Now while I and really any fairly knowledgeable person knows that the modifications done to my car wouldnt cause this kind of damage - this is the same dealership that tried to reject my claim of a damaged clutch cause I had aftermarket Billet "SS" pedals with screws that protruded through the back of them which were APPARENTLY cathcing on my floor mat thus causing the clutch pedal to stay depressed.
So with something as serious/expensive as this - I am not taking ANY chances.
