Stock exhaust question
Old Nov 12, 2002 | 10:44 AM
KizzmySS's Avatar
Default Stock exhaust question
I have a 2000 SS. It is bone stock and I am contemplating getting the Loudmouth exhaust because the stock exhaust sounds like a sissy. Although I looked at my current exhaust and it is rather large pipe. Does any know what size pipe the SS came with? It is much larger than my girlfriends 2001 Z28. With that in mind should I forget the Loudmouth and just get a better muffler and keep the stock pipe, or quit being a puss and get the Loudmouth? If a new muffler is the choice, what is a good, loud replacement. Thanks
Old Nov 12, 2002 | 03:54 PM
ratio411's Avatar
Default Re: Stock exhaust question
The SS was equipped standard with the same 2.75" I-pipe that the Z-28 came with. However, for extra $$$ it could be had with an optional SLP exhaust called "dual dual". This exhaust has a 3" I-pipe. The D/D also has a somewhat better muffler and larger tailpipes. From what It is called D/D because it has 2 exhuast tips on each side of the car instead of just 1 on each side. With either system, just replacing the muffler will free up alot of power... assuming you get a truly good flowing muffler. There is not that much difference between the 2.75" and 3" pipe performance wise. If you happen to have the D/D, then DEFINATELY do not waste your money on a complete system. If you have a standard system, it still isn't worth changing the whole thing IMHO.
Good luck
Dave
Old Nov 13, 2002 | 12:50 AM
Fast Eddie's 02 T/A vert.'s Avatar
Get the Loudmouth or the dynomouth.The dynomouth is very reasonable money wise.
Use the search function,there are many discussions about the LS1 exhaust system.
Old Nov 13, 2002 | 11:08 AM
KizzmySS's Avatar
I measured my pipes last night, they are defineatly 3" pipes. I also measured my girlfriends and hers were 2.5" to 2.75". So you think I should defineatly keep this setup with the dymomouth, eh!!!
Old Nov 13, 2002 | 11:33 AM
DinoZ's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by KizzmySS:
<strong>I measured my pipes last night, they are defineatly 3" pipes. I also measured my girlfriends and hers were 2.5" to 2.75". So you think I should defineatly keep this setup with the dymomouth, eh!!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would say yes! Dynomouth will save you alot of money that you will unneccesarily waste on a full system! Not to mention sound bad azz!
Old Nov 13, 2002 | 04:51 PM
KizzmySS's Avatar
I went home and checked the door jam and there is a sticker there that states, "Modified by SLP Engineering". Is there any way to find out what SLP did to it... Thanks
Old Nov 13, 2002 | 05:10 PM
WILWAXU's Avatar
<strong>I went home and checked the door jam and there is a sticker there that states, "Modified by SLP Engineering". Is there any way to find out what SLP did to it... Thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You can call SLP, have you VIN handy... and build sheet if you have it. You could also post on there user Forum. SLP Message Forum
Old Nov 13, 2002 | 05:24 PM
02SilverWS6's Avatar
<strong>I measured my pipes last night, they are defineatly 3" pipes. I also measured my girlfriends and hers were 2.5" to 2.75". So you think I should defineatly keep this setup with the dymomouth, eh!!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If this is the case, keep the pipes and upgrade to the dynamouth!! It's cheap and simple. I'm pretty sure you'll like the sound too <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
