throttle body port gone wrong!!
Old May 4, 2006 | 08:08 PM
05 GSXR 1XXX's Avatar
Default throttle body port gone wrong!!
ok i ported out my tb...2 problems.
1. i have a spot where i went to deep and have a hole in the wall, what metal putty can i use, and where can i buy it at?
2. in the how to port the tb it says dont lose the small silver washer on the tb, well mine fell out but i dont know where it goes, or if its a press on type washer to hold that shaft in place.
plz respond now! my car has been down for 2 days for this stupid 3 rwhp gain.
Old May 4, 2006 | 08:16 PM
2xLS1's Avatar
https://ls1tech.com/forums/tools-fabrication/497378-i-grinded-through-my-tb-when-porting-how-do-i-fix.html
The washer presses on the end of the shaft, but the TB will work fine even if you leave it off.
Old May 4, 2006 | 09:24 PM
JonB's Avatar
I made a hole in mine as well. I just filled it with some red hi-temp ATV silicone I had in the garage its been on there for a good 8 months or so. It's totally noticably but it works, one day I will get around to fixing it the right way.
Old May 4, 2006 | 10:02 PM
Crazy Man's Avatar
If you cant tig weld the hole shut get some metal epoxy like quick steel ive had it in mine for 2 years. The metal washer slips down over the throttle shaft below the tps sensor. It will probly be fine without the washer but if the blade starts sticking put it back on...
Old May 4, 2006 | 10:30 PM
ChocoTaco369's Avatar
Tech Resident
buy a new ported one from thunderracing and send the busted one back for the core charge refund, but take out insurance on the package with your old TB in it through the post office, then blame them for the damages.
Old May 4, 2006 | 11:29 PM
staringback05's Avatar
man sodder that beast, well depending on how big it is,
Old May 4, 2006 | 11:31 PM
ha wow mail fraud
Old May 4, 2006 | 11:32 PM
BatmobileSS's Avatar
I really hope you're joking
Old May 4, 2006 | 11:41 PM
ok well the hole is right befor the blade so i think ill be fine untill i can afford and new throttle body..
strange i started the car up and it camed like a race car even tho my car isnt camed. then it died, i started it the second time, reved at 1500 rpms for about 5 secs then went back to normal idle.
i took her around the block for about 5 min then came back and checked everything and seems to be fine. just need to fill that hole one day or get a new tb.
wont JB weld melt?
same as the metal putty?
also does that sauter stuff even stick to aluminum metals??
besides tig/aluminum welding, what are my other choices that are for sure to work?
Old May 4, 2006 | 11:47 PM
wont JB weld melt?
i used to work on rc cars, when i sautered stuff it worked fine,your tb doesnt get as hot as some of the other parts do to the fact that the air will continually be running over it keeping it cool, your cars acting funny because of that air getting sucked out the hole, it would be alot worse though if it was on the other side of the blade
Old May 5, 2006 | 12:08 AM
marcdez's Avatar
Dude take it to a shop and have them tig weld it They can do it in like 5 minutes and they probably wont even charge you if they do charge you maybe 5 to 10 bucks. Just make sure the guy knows his stuff if not he will blow a bigger hole.
Old May 5, 2006 | 12:19 PM
sdbrown84's Avatar
Honestly for the trouble of running around get someone in the sales section to get you a used throttle body. Get it, dont touch it, and have a sponsor port it for you if you want it done in the future. That way no more holes.
Old May 5, 2006 | 02:59 PM
2002blackZ's Avatar
if you can't find someone to tig weld it, you could go to Lowe's or Home depot and get a tube of Oatey Epoxy Putty in the plumbing section, pay a little over $4 and patch it yourself. The stuff is amazing IMHO.
good luck!
Old May 9, 2006 | 09:53 PM
Tech Resident
yes...of course i am
Old May 9, 2006 | 11:18 PM
Red2000SS's Avatar
Well, I kind of hoped you were just joking also. Apparently not.
Instead you just come across as a complete jerk / moron. I'm sure after reading your posts, a lot of sponsors and LS1Tech members will be eager to do business with you
Old May 10, 2006 | 03:29 AM
ultraz's Avatar
and for every fraudulent atempt to get one over on EITHER a sponsor or UPS costs the rest of us money.
