FLP or SLP whith do you suggest?
Tim
<small>[ November 23, 2002, 01:44 PM: Message edited by: SSDude ]</small>
DCV performance is having a sale on SL headers with cats and the install kit for $1200! Versus FLP's $1299. Slp's are a superior product that will potentially make more power. Meaning- if any heade puts out more, the SLP's will. Also, the Y pipe is redesigned and tucks u vey nicely, I saw it firsthand. Good luck.
Michael
Bring It <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
<small>[ November 23, 2002, 07:59 PM: Message edited by: Angry'Z ]</small>
<strong>Most would say to go with the FLP. But I would say to go with the SLP. That is what I am going to do even though my car is lowered and here's why. You will get a flatter torque curve with the SLP. At low to mid range the SLP make 10-12 more hp than than the FLP. At the upper range the FLP give about 10-12hp more than the SLP. The LS1 kicks in at the upper rev limit. It's weakness is at the lower rpm range. That is why a Mustang GT will keep up with us up to 60mph. After that, the LS1 kicks butt. So the SLP helps to compensate for the weakness of the LS1 while the FLP doesn't do as much for the low and mid-range area. I would say that the FLP and the Mac's are comperable because they are geared to the upper end of the torque curve. Maybe I am wrong. If so let the flames begin.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Saw a dyno graph from a car that had had MAC's (ORP & 3.5 collector) then SLP's on it. The results were pretty much as stated above. The SLP's did better under 4500 rpm and the MAC's did better above 4500 rpm. I wasn't impressed with the SLP's other than the torque.
FLP's would be my choice over SLP based on install, clearance, etc.
About the only thing SLPs have going for them is their stainless construction, which doesn't even matter if you get your headers coated (like FLPs, hookers, etc). Make more power, and get more clearance, get the FLPs.
Dope
Can you swap to an ORP or and back to cats in under 20 min as with FLP?...NO
Are the SLP`s a pain to install... YES
Do the SLP`s hang lower...YES
Have I seen surface rusted so called "stailess" SLP..YES.[/QB][/QUOTE]
Did i get an off road pipe with my jet hot caoted hookers? Yes....and the 2 together were only $700 shipped
Can i swap to cats with my hookers? Not with the hooker y, but i believe the mufflex y has cats
Are the Hookers a pain to install? HELL NO....just as easy as FLP's or BETTER
Do the Hookers hang lower? NO. In fact, some people have stated they GAINED clearance over stock
Surface rust? Not for a while,jet hot is very reliable and have a lifetimne warranty on rust and will fix it for free(not including labor or s+h)
Seriously, i can't see why anybody would buy headers that cost over 1K <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
<strong>
DCV performance is having a sale on SL headers with cats and the install kit for $1200! Versus FLP's $1299. Slp's are a superior product that will potentially make more power. Meaning- if any heade puts out more, the SLP's will. Also, the Y pipe is redesigned and tucks u vey nicely, I saw it firsthand. Good luck.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do you get an off road pipe and cats with SLP`s?... ..NO
