NW - FAST TB bolt question
Does anyone know if the NW comes with new TB bolts? I dont seem to have more than one bolt that would work? Is the maniold supposed to come with them?
Thanks,
Dave
https://ls1tech.com/forums/generation-iii-external-engine/461554-mounting-fast-90-a.html
But what I don't get is, what bolts are supposed to hold down the front and back of the manifold?
https://ls1tech.com/forums/showthread.php?t=461554
I'm not sure what you're referring to as the 1 throttle body bolt, but we do
not include them, nor do we have any of them. However, you should only use 4
to mount the throttle body to the intake.
-----Original Message-----
WE are getting railed on these FAST manifolds. They SHOULD come with port gaskets, they SHOULD come with stainless hardware, they SHOULD come with TB bolts, they SHOULD have a clip for the MAP sensor, and they SHOULD give head......... for the price.
Stripstar - To answer your question, you need to buy the bolts from a local hardware store. My NW TB did not come with any bolts.
