My GMMG and QTPs
Old May 13, 2006 | 12:54 PM
SS DNA's Avatar
Guys I promise I will post some videos soon. I am Off next Wednesday and Thursday so the install will be done then.
I just bought a video camera too
BTW..... Should I reuse the stock header bolts or should I buy new ones and from where ? What about for my Y pipe ? Is QTP going to provide band clams or do I need to buy them myself ???
Old May 15, 2006 | 11:55 AM
SS DNA's Avatar
What size extensions do I need ? 12 inch or 24 inch ?
Old May 16, 2006 | 10:44 AM
SS DNA's Avatar
Anyone ???
12inch or 24inch extensions ???
Old May 16, 2006 | 08:12 PM
01ss#5536's Avatar
i think 1 of each
Old May 16, 2006 | 10:05 PM
SS DNA's Avatar
I know I need two but what size ???
Old May 18, 2006 | 12:28 PM
SS DNA's Avatar
Well today the install its going to finally be performed !!!
Some teasers !!!
I have a little video but I dont know where to host it
Old May 18, 2006 | 01:20 PM
SS DNA's Avatar
Guys, Am I going to need 02 sims ???
I just got two 24inch extensions ......
My Y pipe as you can see has Cats.....
Sorry for this question but im a newbie trying to learn
Old May 18, 2006 | 03:15 PM
Fire-formula 93's Avatar
You do not need sims. If you want some info on exhaust, read the exhaust FAQ. If you are getting a tune, which you should, the tuner can tune out the rear O2's. If you are not getting a tune and not running O2 sims, you will set off your SES.
How much is this project costing you? Sounds similar to what I am thinking about doing.
Old May 18, 2006 | 08:55 PM
SS DNA's Avatar
**Update**
I been working on the car since 2pm today and so far I have the GMMG on and the I pipe. Im taking the headers out as we speak or type .
I been taking picutes... I will post all that later
Old May 19, 2006 | 12:18 AM
ynkssws6's Avatar
good luck with the y pipe....it's def a POS and it seems more and more people are having problems with the headers.....but stick to it and take your time have patience cause the first time you go WOT it'll all be worth it.
Old May 19, 2006 | 12:50 AM
CaliboyTA's Avatar
ever where u getting it done. I would love to hear the setup in person.
Old May 19, 2006 | 01:49 AM
  #32
SS DNA's Avatar
Im doing it in the good ol' garage
Do you guys have any tips on how to slide the driver side header in ????
I already took off the oil filter so I can have more clearance but nothing yet....
Old May 19, 2006 | 01:50 AM
  #33
SS DNA's Avatar
CaliboyTA,
If you want we'll meet up....
I would like to see how your car looks with Hotchkis.... Those are the springs I want for mine.....
Old May 19, 2006 | 02:34 AM
  #34
CaliboyTA's Avatar
Originally Posted by ~ever~
CaliboyTA,
hotchkis are not installed yet. Im waiting on koni sa. but if u still want to meet up we could. I'm acually gonna be in san jose ( willow glen area) tomorrow (may 19) the whole day but i'll be free before 2pm. i'll pm u my number
Old May 19, 2006 | 03:32 AM
  #35
TheBlurLS1's Avatar
That's what she said...
Im doing it in the good ol; garage
Get the car high enough to point the collector straight down. This was what we did when installing my friend's Kooks.
Old May 19, 2006 | 03:56 AM
  #36
SS DNA's Avatar
Cool
TheBlurLS1 can you give me more details ????
And CaliboyTA, Im stopping for the night.... I hope tomorrow i get the car running....
Old May 19, 2006 | 03:59 AM
  #37
TheBlurLS1's Avatar
First off, you need to jack the car WAY up. I'm talking phonebook that bitch (see link). Then point the collector straight down at the ground and try to ease it in. The more room you have, the more possibly ways you could position it.
http://i38.photobucket.com/albums/e1...nphonebook.jpg
You could also try unbolting the tranny mount and shoving the trans toward the passenger side of the car (be careful). Yet ANOTHER possibility is to put the jack under the bellhousing and try to jack the motor up.
It will usually fit after enough wiggling and cursing. You may think you've tried every possible position, but you haven't tried the one that let the other 5k people install theirs.
Old May 19, 2006 | 04:15 AM
  #38
SS DNA's Avatar
Like I said, Im tired and im going to bed now.... I will try tomorrow....
Old May 19, 2006 | 02:24 PM
  #39
SS DNA's Avatar
Default When installing QTP headers.......
What parts did you guys grind off ????
Im having a hard time putting the driver side header in..... Im so close to finishing my Full exaust intallation but that header is freaking messing it up....
Pictures will be very helpful!
Thanks !!
Old May 19, 2006 | 02:49 PM
  #40
radz282003's Avatar
Get the car up as high as you can. You have to be able to nearly stand the header on it' s end and sneak it into the contour just behind the rear lower control arm pivot point. It you don' t get the header almost perpendicular to the ground, you will not be able to sneak the flange through the opening. Then, as you push it into the opening, you will want to start to tilt the collector toward the floor, in order the get the flange through the opening. You may have to pull the oil filter off, and possbily the drain plug. It will go it. You shouldn' t have to pull the steering shaft. I don' t have photos, here at work, but just get the car as high as possibly safe.
Good luck.
