My GMMG and QTPs
Old May 19, 2006 | 02:55 PM
  #41
SS DNA's Avatar
Hey thanks for your help, I need the most help I can get ......
Im doing this all by myself !
Let me try it......
Old May 19, 2006 | 03:21 PM
  #42
radz282003's Avatar
Just be patient. They should go in without trouble. I have done two sets of QTPs and didn' t have problems. Just get the car high, and it should slip right in ;D
Old May 19, 2006 | 03:26 PM
  #43
jqhawk's Avatar
I did have to remove the oil filter on mine but some say you don't. No grinding on my car either. They fix great and don't rattle. Best headers I have ever owned.
Old May 19, 2006 | 03:47 PM
  #44
radz282003's Avatar
I have been able to do it, now, without removing the filter, but, that was after I had done it already.
I didn' t have to grind my old standard QTPs, BUT, I had to with the new HVMCs. I had to grind below the #2 primary tube, on top of the K-member, but, oh well. It doesn' t hurt anything, and maybe my motor mounts are starting to sag a bit. But, it does not seem to be a common problem. Each car is a little different. That' s how GM makes them...
Old May 19, 2006 | 04:03 PM
  #45
SS DNA's Avatar
Hey guys! I got it on!!!
I had to grind the K member a little and a little square part on the block with a Dremel and a stone
Now I need a second pair of hands to help me hold the headers while I put the bolts in or the other way around
Old May 19, 2006 | 04:06 PM
  #46
SS DNA's Avatar
*Update*
Today I started working on the Driver side header and after much playing around I got a Dremel out and grinded the K member a little and a little block of metal on the side of the block to make it fit.
I will start putting on the Y pipe and tighten everything down and off I go for a quick testing
Old May 19, 2006 | 06:14 PM
  #47
SS DNA's Avatar
Default GMMG users please come in
Did you guys have to cut the I pipe to hook it up to the Y pipe ????
I have QTPs with the QTP catted Y and the I pipe on the GMMG is too long....
Im just trying to get some input......
Old May 19, 2006 | 07:15 PM
  #48
gettinthere's Avatar
My Kook's catted Y hooded up just fine.
Old May 19, 2006 | 07:20 PM
  #49
BOTTLEFEDLS1Z's Avatar
I had to cut 6" off my Borla I-pipe to get the FLP'S to fit
Old May 19, 2006 | 09:57 PM
  #50
bitchncamaro's Avatar
Had to cut 2'' of my kooks Y pipe and had to fab new hanger's on my gmmg (fit perfect with stock setup)
Old May 19, 2006 | 11:15 PM
  #51
SS DNA's Avatar
Ok I had to cut about 1ft to get it to fit....
Old May 19, 2006 | 11:17 PM
  #52
SS DNA's Avatar
Ok... Im DONE!!!!!! Finally!
One BIG problem though..... The QTP catted Y, is way too low.... The driver side cat hits on everything and im not even lowered....
Old May 19, 2006 | 11:21 PM
  #53
SS DNA's Avatar
Default People with the QTP catted Y pipe come in!
Hows the quality of your pipe ????
I have a problem with the driver side cat. Its way too low and it hits on everything
It looks like the problem is at the Y merge collector, It seems like the tubing that goes to the driver side is pointing down too much.....
I really dont know what to do....... I cant drive it like this, it even hits when im on the freeway and there is like little coasters or bumps.....
Can you guys please post pictures of the catted Y or the exaust so I can get an idea of what to do ????
Thanks!
Old May 20, 2006 | 01:22 AM
  #54
SS DNA's Avatar
Thumbs down Problems with Header/ Y pipe installation
I installed QTPs and their catted Y pipe today and the Y pipe hangs real low. Its hitting on everything....
Another big problem, The driver side header hits on the steering shaft, What can I do about this ?????
Thanks for any help!
Old May 20, 2006 | 03:57 AM
  #55
TheBlurLS1's Avatar
That's what she said...
Please help this guy before he starts 500 more threads!
Old May 20, 2006 | 10:35 AM
  #56
Order 66's Avatar
You need adjust the y pipe. If you doing this on your back with jack stands its really difficult. You need another set of hands to hold the pipes in place then you tighten the clamps down. If you doing this by yourself it wont sit right. Also the merger collector does not site flat. If you rotate it to the passenger side it will bring the driver side pipe up. You also can bring it to a muffler shop to have them adjust it for you and get it done. It might be easier that way. Like i said on your back is very, very difficult.
Old May 20, 2006 | 02:13 PM
  #57
SS DNA's Avatar
What about the sterring shaft ??? Can I grind a little off of it or not ???
Any fix to this problem ???
Old May 20, 2006 | 03:30 PM
  #58
TheBlurLS1's Avatar
You can take the bolts out of the steering shaft (only like 2 of them), and try to slide it up or down so it'll fit better. You'll see a little adjustment area in the shaft right by the header.
The splined shaft on the rack has a slot for the bolt to keep it from sliding off, so it has to go in THAT spot.
Another idea is to, brace yourself, put a dent in the primary tube.
Old May 20, 2006 | 06:42 PM
  #59
SS DNA's Avatar
Im going to try the shaft first.....
If not, I dont know what im going to do
Old May 20, 2006 | 07:20 PM
  #60
GOT2BSS's Avatar
ever
all said and done (I know you are not done) would you install QTP headers again? I'm waiting for mine, but after reading posts here I'm thinking I may look at other options.
