Any input on the Quicktime dual cutout Y?
Old Dec 8, 2002 | 10:14 PM
absolut_speed's Avatar
Default Any input on the Quicktime dual cutout Y?
Has anyone installed the Quicktime dual cutout Y with their headers? I'm looking for feedback on quality, sound (drone due to their location) etc. Is the sound or drone easily controlled by only partially opening the cutouts for daily driving?
Thanks.
Old Dec 9, 2002 | 01:11 AM
NX†C's Avatar
Default Re: Any input on the Quicktime dual cutout Y?
i can let you know later on this week...
headers and y arrive tomorrow and install will happen this weekend <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ December 09, 2002, 01:23 AM: Message edited by: X']['C WS6 ]</small>
Old Dec 10, 2002 | 12:04 AM
Ian's Avatar
Ian
anyone know what the difference in power/performance this y pipe would have over 1 QTP cutout in the I pipe?
Old Dec 10, 2002 | 01:39 PM
Colonel's Avatar
I think at mild to moderate power levels you're better off with one in the I-pipe especially if the Y-pipe and I-pipe aren't very restrictive for your power level.
Old Dec 10, 2002 | 01:57 PM
gator's 99TA's Avatar
colonel, what do you mean by mild to moderate power levels? stock? bolt on? cam? H&C? is 350 RWHP an indicator? just wondering.
Old Dec 10, 2002 | 02:31 PM
Colonel's Avatar
With a properly designed Y-pipe (like I had on my 422 setup at one time) you'll make just as much power through the Y-pipe as you will with open headers. We dyno tested this on my car.
We tried it with open headers.
Then we tried it with a 2.75" into 3" Y-pipe. We droped like 20-30 HP to the ground. It's been awhile so I don't remember the numbers but I do remember the idea.
Then we tried it with MTI's custom built 3" into 4" Y-pipe. It made the exact same power as the open headers.
So, in the case of the smaller Y-pipe I stood to make GREAT gains with dual cuttouts over a single cuttout. But, in the case of the larger Y-pipe I stood to gain zero HP with the dual cuttouts over a single one.
Old Dec 10, 2002 | 02:52 PM
Colonel's Avatar
BTW, to put things in perspective in regards to flow. A 4" pipe will flow approximately %78 more volume at a given pressure than a 3" pipe. Doesn't seem like it would be that much difference does it?
<small>[ December 10, 2002, 02:53 PM: Message edited by: Colonel ]</small>
Old Dec 10, 2002 | 02:53 PM
well i have a very small y-pipe (2.5" non-mandrel bent) so it is like 2" at its worst. i have thought out opening the dual cutouts to see if i gained. most dont have a y pipe as bad as mine
Old Dec 10, 2002 | 02:55 PM
Colonel's Avatar
How is your Y-pipe so bad? Custom job gone haywire?
If it's the stock Y with the flat spots, don't worry about them. GM was very careful not to impede flow with those flat spots. That pipe flows just as well as a round pipe.
Old Dec 10, 2002 | 02:58 PM
no it is just a quickie cheap job done at a local muffler shop. i have these dynatech headers and that drivers side is a severe bend to get it back to the y-collector. also, the muffler guy said he couldnt bend 3" that much. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> it was real temporary but now i am sick of it. i have dual cutouts on there too. still no one makes y's for dynatechs i guess.
Old Dec 10, 2002 | 03:52 PM
Colonel's Avatar
Couldn't an FLP Y-pipe be made to fit? They are basically the same header but in street form.
Old Dec 10, 2002 | 03:54 PM
hmmm, never thought of that. i think the collector might be a bit longer on the dynatechs. i will have to call around.
Old Dec 10, 2002 | 10:52 PM
JS's Avatar
JS
I guess the duals couldnt hurt but are they needed?
FWIW,I'm running Hooker LT's to a 3in Y to a 3.5in merge to a 3.5in cutout and thats working just fine.
Cant argue with 122MPH at 3450lbs <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
JS
<small>[ December 10, 2002, 11:30 PM: Message edited by: JS ]</small>
