bolt-on car and duals..2.5in or 3in? people who know help me out
i will be on the bottle some too but my main goal is as fast as i can stock internal. 11.60's right now. I will be spraying some too so keep that in mind. 2.5in will give me no power but more torque right? what about 3in? i am making around 360+/370+ right now. this will be an X pipe too. should i go with the tradition bullet mufflers? i am not really a fan of being loud anymore but i know it will be loud still; should i go with borla xr-1's?
thanks
thanks
Jamie - I'm going to try a 3" to the X and out, and the reduce to 2.5" through Magfaflow Magnapacks - 4" diameter. Should be the best of both worlds, rwhp and rwtq wise. The MM mufflers will be quieter than the bullets, but still have straight through power. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I'll be posting how it turns out dyno and track wise, but that's a system you should think about. Mike(Beenfetched) was on the right path when he did the same thing, but chose the wrong muffler - the Flo-Pro. Live and learn.
Your peak gains might be minimal, but you should see a good gain in the midrange.
<small>[ December 16, 2002, 03:33 PM: Message edited by: Lane ]</small>
I run true 3" in and out.I just did a car this weekend with flp's,3",xpipe,& a bassani dual in dual out muffler.This muffler is straight thru design.It is by far the best sounding true dual I have heard borla's,bullets,& flow's.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by justin sutton:
<strong>I run true 3" in and out.I just did a car this weekend with flp's,3",xpipe,& a bassani dual in dual out muffler.This muffler is straight thru design.It is by far the best sounding true dual I have heard borla's,bullets,& flow's.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Where'd you put the muffler?
<strong>I put it under the passenger side under the rear seat.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'd really like to see some pics of that. I want to go that route. email them to me if you can.
j_arends@hotmail.com
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JS12:
<strong>lane, what do you think about some borla xr-1's?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I think they would work great, but $$$$$
I have 3" to X, then 3" to the 2.5" eldebrock mufler. Fits up in there great. 3.6" case x 7". I wanted to quiet it down over the bullets. I got back the TQ I lost with the bullets. It didn't quiet it down as much as I wanted to, but much better that before. I'll deal with it now.
I already had 3" with the bullets, and thought the 2.5" would be quieter, so I just had the ends expanded out to fit the 3" pipe. I use band clamps, so I can take them off it I want, like when I'm going to spray the car.
Restricted User
Justin Sutton, if you got pics and clips of the TD w/ bassani can you e mail them to me as well, fukawe@hotmail.com I have 2.5" from the cats into a 90/10 "X" and then bullets under the axle and out, anywya to fix the droning at 2-3k? TIA.
Charlie.
Charlie.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have 2-1/2 all the way to the x-pipe and then into bullits and turn downs. 3 inch is to much for a stock motor.
I have 3" with an x on my ss.Only bolt ons.I do spray it but I have lost no low end what so ever.I don't see why you say it is 3" is to big.
I'm going to an x-pipe setup soon as well. The car will have a 396 stroker, no power-adder probably within a year. I want to go over the axle with the tubing. Will 3" fit if I take out the upper panhard brace?
Jake yes it will fit.It is a bit tricky but you do have to remove the panhard brace.3" will fit it can be and has been done.You need to take your time when doing it.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Black Sunshine/ 00SS:
<strong>3" was good enough for 11.49@117 with bolt ons only, for my car. Trust me, it's not too big!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Even though I went with 2.5", I've always used your car as an argument against 3" being too big.
From what we've seen on our systems, 2.5" and 3" make basically the same power on bolt-on cars. But, the 3" will really shine on heads/cam cars. We have a couple over 400 rwhp with stock heads.
