A4 and ported MAF Ends...
Old Dec 29, 2002 | 10:19 PM
99ssleeper's Avatar
Default A4 and ported MAF Ends...
I have heard that porting the MAF Ends on an A4 car reduces line pressure. Could I use the ported ends if I have a HPP3 to raise line pressure?? Anyone done this?? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Dec 30, 2002 | 09:07 AM
Xsta Z 28's Avatar
Default Re: A4 and ported MAF Ends...
I have the 85mm MAF on my auto SS and have no trans problems. Don't honestly see how the tow can be related, but with todays cars how knows.
Old Dec 30, 2002 | 09:23 AM
unit213's Avatar
Administrator
" Don't honestly see how the tow can be related, but with todays cars how knows."
I'm not 100% sure, but I believe the PCM looks at MAF flow rates to determine transmission line pressure. A ported MAF or MAF ends allows "undetected" air to pass. As a result, the PCM doesn't increase line pressure to compensate.
Someone else want to chime in here?
Old Dec 30, 2002 | 10:32 AM
Dope's Avatar
Do a search on it, there's been tons of discussion on it before. General concensus (including my own) is that it's a DO-NOT-DO kinda mod. Tranny shifts all sloppy with MAF ends, I took that crap off immediately and put the stock ones back on.
Dope
Old Dec 30, 2002 | 10:52 AM
1/4master's Avatar
does that go for GMAFS also. there was $300 down the tube. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old Dec 30, 2002 | 10:56 AM
1/4master's Avatar
or does it not effect GMAFs since they are calibrated for more airflow?
Old Dec 30, 2002 | 11:49 AM
unit213's Avatar
Administrator
I don't have any personal experience with GMAF's, but it's my opinion that the MAF is not a good thing to mod. The only thing I'd consider doing is putting MAF ends on a M6. The stock MAF can handle well over 450rwhp and I'm pretty sure much more than that.
"does that go for GMAFS also. there was $300 down the tube."
At least it looks nice. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Dec 31, 2002 | 12:01 AM
Supertrapped's Avatar
Speed freak
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by camaro_ls1:
<strong>
Someone else want to chime in here? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Correct. But the damage, if any, is so minimal it would go unnoticed. You probably wouldn't see anything until later down the road. I have an A4 with ported MAF ends and 80k miles on my car. I race quite often too. Haven't ever had any problems with the tranny. Then again, every car is different.
Old Dec 31, 2002 | 12:04 AM
unit213's Avatar
Administrator
Hey DevilBird...I have a question for you. Do you ever hit the rev limiter while at the track? I've hit the limiter a few times with just a descreened MAF. I don't think that has anything to do with it actually. My tranny fluid was a bit low. I'm sure that was the culprit.
Old Dec 31, 2002 | 12:06 AM
Speed freak
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1/4master:
<strong> or does it not effect GMAFs since they are calibrated for more airflow? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Its calibrated...so don't worry, you're cool <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 31, 2002 | 12:08 AM
Speed freak
<strong> Hey DevilBird...I have a question for you. Do you ever hit the rev limiter while at the track? I've hit the limiter a few times with just a descreened MAF. I don't think that has anything to do with it actually. My tranny fluid was a bit low. I'm sure that was the culprit. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Keep your tranny fluid full. Mine used to do it when my tranny fluid was a little low. Filled it back up and no more bouncing off the limiter. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 31, 2002 | 12:18 AM
jpz28's Avatar
Well I have an a4 98 and I ran the ported ends for a while and while at the track...it slipped and I stopped from there and had the tranny checked.....So I had the fluid change and everything done and it fixed the slipping and I was still running the ported ends...mind you no pimging!!!......then I bought a pair of stock ends with the screen in em and noticed no major difference either.....no tranny problems so I think it depends on the car and the condition of your tranny whether its well lubed and it is kept in good maintainance....which I read often that these trannies are very vulnerable when not serviced.....which usually tends to be the cause sometimes.....but it just depends....just my 2 cents..... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
