Quiet True Dual Idea!!!
It is 14" long, is that to much past the X?? From what I have heard mine and a true dual is about the same external and this should reduce it even more, and the dumps will bring the cabin back up, hence maybe about the same. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Anyway, the problem with those mufflers is: where are you gonna fit those? The length isn't the problem, 14" is fine, but where are you gonna fit them horizontally and vertically? They are 5" high, whereas your normal bullet is 3.5" I believe. Even if you tuck them up you're still gonna lose close to 1" ground clearance (a lot). Then, where are you gonna fit all 10" of that width? There's no room under the car for that, so you'd have to have the mufflers right off of the floor pan, which means you'll be losing 5" of ground clearance (theoretically), I know the loudmouth doesn't tuck up fully).
If you ran the pipes out the back, and THEN the hookers, you'd be ok. If you put them before the axle though, good luck. Even on a stock height car, they'd probably be 2" off the ground at best. If it's a drag-only car, then you'd be ok, but if you like to drive it on the street, forget it!
Dope
what about this the two bullet x and then run it back to the back and before it exits go through two more bullet or the mufflers??? I really want turn downs!!!!!!!
What can i do to have about the same interior volume with turndowns??? It would be different if it was a T/A because thay have notches for the exhaust, so to me it looks right. While my ss looks like it should not have exhasut out the back.
So what is a solution for turndowns and being quiet??
They will almost never be quiet, unless you add tons of muffling. Sound coming out of the turndowns reflects off the ground and back up towards the car. Think of yelling in an alley versus yelling on an open field. The sound refects under the car.
The biggest problem, though, is the noise level INSIDE the car with turndowns. The noise is extreme because of the sound relecting back at the under side of the car.
So, how much do you want turndows again?
SF
Just thought if you wanted quiet that bad, you might be interested...
Dave
Justin
Michael
Angry, he is talking baout putting bullets off the headers before the X ( like mine ) and then 2 more mufflers after the X. There is enough room for that.
Justin
