Help with removing crank pulley
<strong> I loosened the crank bolt, took it out some, then I put the 3 arm tool on and went to work. I got to about the last 1/2 of the tool when all of a sudden, with each turn I did, the car jolted forward a bit! I don't know what to do. I tried prying the pulley off but it won't budge. ??? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You maen the pulley got tighter coming off? Are you up against the crank bolt if you only loosened it up? Shouldn't you take the crank bolt off? Make sure you set the hand brake firmly cause if the car is moving you're turning the engine.
Anyway, after lots of prying and swearing I got it off. Thanks!
