Idle Question After Boltons
Old Jan 6, 2003 | 07:28 PM
promod1955's Avatar
Default Re: Idle Question After Boltons
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
<strong> Sounds like a serious vaccume leak to me. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thats what i was thinkin.
Old Jan 6, 2003 | 10:12 PM
Z 2 L8ter's Avatar
Thanks for the replies! Where could a vacumm leak be? That doesn't sound too good! Anyone else have any ideas?
Old Jan 6, 2003 | 10:27 PM
DONAIMIAN's Avatar
check around the throttle body
Old Jan 7, 2003 | 12:27 AM
Z 2 L8ter's Avatar
Default Idle Question After Boltons
I recently got done installing my Hooker LT's & orp, a bauer ported tb, and FTRA. Now my car seems to idle high at around 1500 rpm or a little higher. Also when I am driving and push in the clutch the car will rev up to about a little over 2 grand and then go back down to a slower idle at 1500. (Not good if I see cops to have it revin up) What could be causing this? Does it just take time for the computer to learn the mods or is it something else? One other thing is when you drive the car and get on it I hear like this wining noise or something. I thought it could be the check valves fluttering but I did the restrictor mod right away. I have no clue what the sound is. You guys got any answers to my problems?
Thanks,
Jeremy
Old Jan 7, 2003 | 12:45 AM
SStrokerAce's Avatar
E-mailed you some things to try
Old Jan 7, 2003 | 12:48 AM
Colonel's Avatar
Old Jan 7, 2003 | 01:17 AM
sited12's Avatar
EGR and AIR tubes is another great spot for the leak. Its just sucking in air from some other place instead of from the air box. Did you replace the EGR and AIR gaskets. Also what year is your car. Hooker headers are for 98 and 99 AIR tubes so if you have a different year that might be a problem.
Old Jan 7, 2003 | 01:39 PM
Z 2 L8ter's Avatar
My car is a 98 and I did replace the egr and air gaskets so I hope there isn't a leak there.
http://community.webshots.com/user/jr3334z28
Old Jan 7, 2003 | 01:49 PM
Colonel's Avatar
Also check the accordian tube that goes from the MAF to the TB. Make sure the clamps are tight and everything is all the way on as it should be.
