Whats wrong with my a/c?
Old May 22, 2006 | 12:07 AM
Y2K Pewter SS's Avatar
Default Whats wrong with my a/c?
Its blowing ice cold air on the feet, but won't blow anything out the dash vents. The only thing that has changed on the car recently is the underdrive pulley was put on. Since its blowing ice cold on the feet, I really don't think the compressor is going out.
Would the UD pulley have affected it that drastically? Maybe a vaccuum leak somewhere? Any suggestions are appreciated.
Old May 22, 2006 | 12:08 AM
xaon's Avatar
check the vacuum line on the back of the intake
Old May 22, 2006 | 12:19 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That would be your culprit.
Old May 22, 2006 | 12:21 AM
Black_Bird's Avatar
Definitly a vacuum leak, seen the case many times before.
Old May 22, 2006 | 12:25 AM
TheBlurLS1's Avatar
That's what she said...
^^^ What they said. ^^^
https://ls1tech.com/forums/generation-iii-external-engine/505979-fast-intake-provisions.html
You'll see some pics of the manifold in those pics. There's a little (approx. 1/4" OD) fitting coming off the back, pointing toward the big plastic a/c box/plenum thing. That vacuum line controlls the "trap door" which is what makes the pshhh sound when you turn the selector **** in the dash.
Trace that vacuum line untill you find the leak. It goes to part of the AIR system, a couple of T fittings, to a vacuum canister, to the a/c system etc. The line runs inside the wireloom crap that is on the passenger side fender.
Old May 22, 2006 | 12:32 AM
https://ls1tech.com/forums/showthread.php?t=505979
I checked the t fittings that are on the wireloom near the passenger side fender, they were good. I am fixing to do a heads/cam install, so I will trace it all when I tear it down. Thanks for the advise guys, greatly appreciated.
