EGR HELP!
Old Jan 13, 2003 | 04:36 PM
JOB3's Avatar
Default EGR HELP!
Ok so I cut the EGR about a 3 weeks ago, now the Brass Heil-coil has broken loose from the maifold, WTF do I do now?? Set off my service engine soon light, makes a noise let air beling let out of a tire. installuniversity said to be careful of this, thought I was but I guss I messed it up. PLEASE HELP <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Jan 13, 2003 | 04:38 PM
JOB3's Avatar
Default Re: EGR HELP!
Thats "Makes A Noise LIKE air BEING let out of a tire" SORRY Just Fustrated <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Jan 13, 2003 | 05:47 PM
Argon Z's Avatar
just get rid of the whole egr system.
You dont need it anyway.
Just block off hole in manifold and in exaust manifolds...I think slp sells a kit.
Old Jan 13, 2003 | 05:53 PM
unit213's Avatar
Administrator
What you have is a vaccuum leak. Your car probably idles poorly now. My EGR didn't seal properly for a few mins and it did the same thing. It can be replaced I believe. Anyone have the part # or info how to replace it?
Old Jan 13, 2003 | 07:19 PM
JOB3's Avatar
I was thinking about blocking it off but wont my SES light come on? Please more info
Old Jan 13, 2003 | 08:57 PM
unit213's Avatar
Administrator
Yes, you will have an SES code. It can be cleared if you have or know someone with LS1edit.
Old Jan 13, 2003 | 09:29 PM
ShiznityZ28's Avatar
you can pick up a ls1 intake pretty cheep and changing it is very easy.
Old Jan 13, 2003 | 09:58 PM
M3EATER's Avatar
How 'bout.... for the time being, just epoxy the brass thread insert back in with some JB Weld or similar?
You don't want that vacuum leak.... you'll run lean, it's "unmetered" air.
Gordon
www.provenperformanceconcepts.com
<img src="http://www.provenperformanceconcepts.com/PPC%20BANNER%20468x60.jpg" alt=" - " />
Old Jan 14, 2003 | 08:27 PM
ZYouL8R's Avatar
I used JB Weld when I was in your situation. Almost a year later it's still holding up.
