Green coolant mixture in radiator????
Old Jan 21, 2003 | 02:46 PM
jpz28's Avatar
Default Green coolant mixture in radiator????
I have a 98Z and a while back...I had my mechanic put in a new radiator because mine was cracked and kept leaking...Well according to the manual...it states for you to use the orange coolant which I beleieve its Dex cool from Prestone right?....okay...well I think he used the Hi/Lo Oreilly green coolant because I opened up to check the radiator and it had green antifreeze in it....I know he used that kind because i go to his shop sometimes and he has a whole lot of boxes with O reilly coolant...but will it harm anything or mess up anything....I've been running it like that and no problems whatsoever.....any downsides or would I be ok...I plan to change it before the summer but just wanted to know if its all that bad to be running that type of coolant???........sorry for the long post!! <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 21, 2003 | 02:59 PM
jimmyblue's Avatar
Moderator
Default Re: Green coolant mixture in radiator????
Never heard of OReilly. GM doesn't like the
traditional silicate anticorrosion formulas
anymore, don't know for certain why. But I
think anticorrosion appropriate for an
aluminum block with steel sleeves is a
good idea. The dealership would flush and
refill with Dexcool, this would run you a
little money but if you go for warranty
work and they find green juice in there,
you'll be taking el shafto grande. Just my
prediction.
Even if I wasn't worried about that, I'd
be less than pleased about having my car
filled with Billy-Bob's Diskount No-Freez.
Old Jan 21, 2003 | 04:25 PM
ArcticFormula's Avatar
LOL! Jimmyblue,
But is Billy-Bob's Diskount No-Freez, similar to Scooter's green HI-C flavor engine quencher? I must remember to avoid those <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> .
Old Jan 21, 2003 | 04:32 PM
robertbartsch's Avatar
Since the orange cool-aid that belongs there is not expensive, get rid of the lime cool-aid and gargle with clean water before refilling.
Technically, you should not use tap water with the refill. Distilled water is best.
If you do this yourself, make sure you run the motor with the cap off for several miniutes to remove any air bubbles...
Don;t be a pig and flush the old stuff ...recycle it and enjoy our green planet...
Old Jan 21, 2003 | 04:34 PM
99ZEOD's Avatar
From what I've heard the green stuff will eventually cause the water pump to fail. Something about the Dexcool lubes the water pump. (I said Lube) Does anyone else remember hearing something like this or have I had too many beers?
Old Jan 21, 2003 | 04:43 PM
rnr27band1's Avatar
yea the orange is better for the aluminum block and heads and it also lubercates the water pump, i have heard that running the green stuff will wear off the coating on the block and heads.
Old Jan 21, 2003 | 06:21 PM
2000WhiteZ28's Avatar
Dealer will charge 45-60 bucks for flush and fill, its done with a mighty big hose. Green wears the lining material away from the aluminum. Green then seeps into aluminum, sometimes mixing with the oil. Of course, this is over time. You want a 150K mile LS1, I suggest going back to the red Kool-aid, its cheaper these days and doesn't clump up like the stuff back in 98 did. You can even buy it at Target I hear.
Old Jan 21, 2003 | 07:54 PM
DaddySS's Avatar
It is important that you get the green stuff out of there right away. I can tell you from experience and GM has a bulletin on it, that a mix of orange and green equals sludge that will clog you heater core in very short order. There is a complete flush process that must be used to clean all the old junk out and then refill with orange.
I am not saying orange is better, just that it must be one or the other - all orange or all green.
Old Jan 21, 2003 | 08:03 PM
JetBlack98Z's Avatar
Jp Jp JP Damn that suxs, Like everbody else sayed, The mixture of Green and some Orange Coolant will cause a major clog. The whole piont of the Orange coolant is to protect the Alumium heads & block <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Laterz Steven
Old Jan 21, 2003 | 08:07 PM
Orange Krush's Avatar
Ditto what Daddy said! <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
In 2001 I worked for a major trucking company whose fleet of 2000 3500 series duallys all were incapacitated by the practice of mixing green and orange after a routine winterize! <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
It turned to a jello like consistency after about 45 days and did major engine damage to all contaminated vehicles! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Flush everything and re-fill with Dex-cool, or pay the price! <img border="0" alt="[cry]" title="" src="graemlins/gr_cry.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 22, 2003 | 08:11 AM
jpz28's Avatar
Thanx guys gonna do that either today or tommorow depending on the weather......So I should go ahead and fill it up with Dex Cool only?.....I mean add no water?........so I would have to buy a couple a gallons of that orange stuff huh?....Will do.......
Old Jan 22, 2003 | 09:02 AM
NO - NO- NO!!!!!
The mix is 50% orange cool-aid and 50% distilled water....read the label!
Filling your system with 100% red cool-aid and no water will result in a less effective cooling system....besides being twice as costly...
Old Jan 22, 2003 | 09:16 AM
jpz28's Avatar
Dope!!...my bad...okay 50/50 right?.....riiiight?
I probably didn't understand what you all were talking about....but I got it now! <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Jan 22, 2003 | 01:29 PM
Ditto what Robert said! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Here is a link to help out! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
http://www.theherd.com/articles/dex_cool.html
http://www.coolprofits.com/articles/...l-macs2001.htm
Old Jan 22, 2003 | 03:48 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
The orange stuff is available from Havoline, same specs,AFAIK,as GM -and is reccommended as a replacement- by GM. With the majority of the components the cooling system is composed of being aluminum, GM figures the orange stuff is better.
Mixing "standard" with the "long life" is discouraged, although I don't know the technical reasons why.
A 50/50 mix of antifreeze/water yields maximum overboil protection, from what I've read. Above that actually gives less protection for high heat conditions. What mixture gives the max protection from freezing, I don't know.
There are other products available to considerably raise the boiling temperature while running mostly water, but I can't speak for their metal protection capabilities,as I just don't know.
In any event, don't run plain old tap water unless you have very clean, demineralized water.
Old Jan 29, 2003 | 12:20 AM
Chivalry101's Avatar
Well, I know what I am doing tonight! Can anyone recomend anything to help flush out the radiator, or just use water?
