Any problems reusing the stock header gaskets?
Old May 24, 2006 | 09:57 PM
Speedmonster185's Avatar
Default Any problems reusing the stock header gaskets?
I just recieved my new Pacesetter LT's in the mail and I just have one question. Is there any problem with using the stock gaskets for the Pacesetters after I take the stock manifolds off? Thanks
Old May 24, 2006 | 09:58 PM
2K2WS6TA's Avatar
Most of us use the stock metal gasket (either a new set or the original) works fine lasts long time
Old May 24, 2006 | 10:26 PM
isorms's Avatar
yup, I used the metal gasket too...
Old May 24, 2006 | 10:29 PM
3521SS's Avatar
Old May 24, 2006 | 11:13 PM
blkbird's Avatar
I used my stocker metal ones...
Old May 24, 2006 | 11:25 PM
Scotty-Z's Avatar
On my 2000 Z28 that had 37k miles at the time, I bought some new ones from GM for like $35. On my 2002 Z28 with 28k miles, I just reused the stockers.
Old May 25, 2006 | 12:57 AM
natronathon's Avatar
Its only a little bit of money to get new "stock" metal ones. Just buy new ones, cause if your gaskets go bad, you will regret having to replace them later... like 20 bucks from speed.com
Old May 25, 2006 | 02:35 AM
2002ssls1's Avatar
I was going to say the same thing. I bought new ones when I did my install. I took my old ones off and the layers were seperated and I figured it was worth th eextra money for gm gaskets. Do it right th efirst time.
Old May 25, 2006 | 09:16 AM
GuitsBoy's Avatar
I reused my stockers twice, but replaced them with new GM ones the last time I swapped heads. Never had a problem with them.
