PCV System Question
Old May 26, 2006 | 09:58 AM
BLACKOUTZ28's Avatar
Default PCV System Question
Okay guys...well I checked the car last night and found out that my PCV line is broken. The line that is broken is the one behind the block; it broke where the driver side valve cover and the passenger side meet...you know the little Y that it has. I was thinking about replacing all the hoses and just eliminating the PCV Valve. So would it hurt to run the PCV system without a PCV Valve with a catch can?
Steve
Old May 26, 2006 | 10:04 AM
rgaynor85's Avatar
the valve controls the flow of crankcase pressure it is needed dont loose it i think that would be bad
Old May 26, 2006 | 10:46 AM
GuitsBoy's Avatar
Yeah, keep the valve. Just rig up some attachment of some sort.
Old May 26, 2006 | 10:53 AM
Well I ordered a breather last night but that will probably take about a week to get here. So I wanted to do something to fix the problem temporally, I don’t really want to drive the car like that.
Steve
Old May 28, 2006 | 12:20 AM
TheBlurLS1's Avatar
That's what she said...
My hose back there screwed up too. I took a piece of hose that I stole from the old AIR system and, bored it out a bit, and it slipped over that Y junction.
Old Jun 6, 2006 | 08:41 AM
Okay guys the breather came in.
So what all do I remove from the PCV System?
Do you think the Moroso breather will work fine?
Or do you guys think that I should just keep the PCV System w/ Catch can?
Steve
Old Jun 6, 2006 | 09:18 AM
Z28LS1camaroguy's Avatar
what i did to delete the system was, ran a 3/8 inch hose from valve cover on the passenger side to the valve cover on the drivers side, then blocked off the intake nipple with a rubber cap. And then put the breather on and works great, no problems.
Old Jun 6, 2006 | 10:44 AM
TheBlurLS1's Avatar
I took some short piece of 3/8" hose, dabbed some RTV on some small bolts, shoved the bolts in the hose and hose-clamped 'em in place. Then I slipped them over the rear PCV ports, put a small red rubber cap on the manifold, and stuck the breather on.
I also left my fresh air tube (tb to valve cover), but put my PCV valve in the line in such a way that it prevented crankcase gasses from going into the manifold (like a check valve).
If the check valve idea doesn't make a difference, oh well, it was free.
Old Jun 6, 2006 | 10:45 AM
What about the hose that goes from the valve cover to the throttle body?
Thanks for the help.
Steve
Old Jun 6, 2006 | 11:12 AM
it still on there
