Any way to clean MAF wires?
I guess that electrical contact cleaner is about as harsh as you could go, but I think that the wires should heat up to a fairly high heat every time the engine is shut off, but it isn't up to red hot hot so there is no visible cue, which is intended to clean the wires off.
Maybe your wires are not heating up?? Something else to check out.
https://ls1tech.com/ubb/ultimatebb.p...=005727#000000
Blue Shower from Radio Shack looks like the way.
<strong> I clean the MAF wires every once in a while....I take a few Q-tips and soak em briefly in a little bit of alcohol and carefully clean the wires very gently using a clean Q-tip for every wire....I also clean the horizontal thin bars that run across the MAF the same way....using a clean Q-tip every time ......Be careful.....you have to be very gentle....having small hands would help......but be careful!!!!!.......!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">when i ported my MAF the wires were filthy and thats exactly the way i cleaned them with no problems at all. JUST BE CAREFULL <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
JR
JR
