Synergy All in One product line....
The first box is our "All in One" box. This box contains our Two step function, adjustable window switch, nitrous controller, purge, ect. What that means is we are able to use the box in place of the relays on your nitrous kit. The box will now act as your gateway for all controll over your purge, and your fuel and nitrous solinoids. It also has protection from open circuit, short, and over voltage with full LED status to let you know whats going on. There is also an overheat protection as well. The window switch will be adjustable in increments of 100 rpm like most other units out there. The two step will function the same way. On the purge, you have a mode switch from automatic or manual function. In the manual function you can set it up as a burst or solid state so you can adjust how it purges. The box also has a seperate output for either controlling signal to a bottle heater or bottle opener. Of course you will need seperate electronics for those too, but it will basicly allow you to signal to the other devices to arm or activate.
The unit is also fully upgradable at anytime. Customization is also optional upon contact with us to fit your needs.
The active cost right now for this All in One box will start around 350.00.
The other little item we offer is what we call the smart switch. Its an electronic circuit where you can controll 4 functions. So say 2 on and 2 off. Or either 2 on and one open/close. So when you have limited space in your car for more switches and relays, your options become slim. The smart box takes care of this for you. Its about space savings like the all in one box. This will take care of your amperage problems without having to have relays again. You will also be able to controll more than just one item at a time with the same box instead of having multiple buttons or switches. The box can be customized for on/off or open/closed functions. For the open/closed functions, this can be adjusted when built to controll your electric cutouts or your remote bottle openers. What that means is the box will automaticly open and close your device at the push of one button. No more holding your button counting the seconds till something is open or closed. It basicly works for any like device.
This box can be sold with or without the buttons and will have to be built upon request. Electronics only will start at 200.00. Custom buttons will add to the cost if customer does not have any.
If you want to purchase the two step or the window switch seperately, you may do so. The cost for each unit will be around 225.00. So when you look at everything, you are getting a heck of a deal for the All in One Box. But sometimes not everyone needs all those functions.
Please feel free to contact us about any questions you may have or any requests you may like to see in future products. Thanks.
Rick
Here are some pics.
We also offer custom button and switch setups upon request as well. Have a look.
... couldn't imagine a po-po looking in and seeing that
