Dynatech Supermax Headers??
Old Jun 5, 2006 | 01:49 AM
CamaroSS615's Avatar
Default Dynatech Supermax Headers??
Why are the Dynatech Supermax headers so expensive? They cost $1,300.00. I thought QTP and Kooks made the nicest headers for the LS1?
Old Jun 5, 2006 | 04:26 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
They are also Stainless.
Old Jun 5, 2006 | 10:14 PM
senicalj4579's Avatar
the supermaxx is a system. it comes with 2 headers,2 high flow cats,y-pipe,2 header gaskets,air tube gaskets,02 extentions,all hardware needed and they are stainless. i will tell you from my experience that this system is an awsome fit and sounds great. everyone thinks they are so expensive but if you do the math and figure what you would need after buying just headers from another brand you will find out its really not bad.
Old Jun 6, 2006 | 12:57 AM
Z2K_MrJ's Avatar
Board Certified Idiot
Dose this Mean cause they coast more you think they are better??
Old Jun 8, 2006 | 01:03 PM
joecar's Avatar
They are expensive but they fit very well, good clearance all around, very easy to install, comes with complete install kit and cats and nice large radius merge Y-pipe (unlike some other Y-pipes that have sharp bend merge).
Old Jun 8, 2006 | 01:06 PM
SSTowerman's Avatar
Got my attention. Who sells this system?
Old Jun 8, 2006 | 01:49 PM
SSTowerman's Avatar
And where did you find that price. I can only find them for about $1500 smackaroos.
Old Jun 8, 2006 | 02:22 PM
No, I just couldent figure out why they cost double of what the QTP and Kooks. Senicalj4579 helped me to understand .
Old Jun 8, 2006 | 02:49 PM
SS DNA's Avatar
Does anyone have pictures of this system installed ???
I have QTPs and their catted Y and it sucks ***, Im looking for better clearance.
Old Jun 8, 2006 | 03:21 PM
radz282003's Avatar
Not to jack the thread, but, I didn' t like the clearance on my QTP cat' d y-pipe. It was worse when I changed converters, and moved the driver' s side onto the collector. I ended up cutting a stamped steel floor crossmember ( 4" X 2" ) to move the cat higher off the ground. Worked okay, but still hangs low.
That Supermaxx system should fit a lot better, because that y-pipe is like 2.5". The Kooks doesn' t look too bad, because they flatten the driver' s side a bit. I wanted a 3" y-pipe, and liked QTP merge collector, so I conceeded to less ground clearance. BUT, the entire Supermaxx system is T304 ( if I' m not mistaken ) unlike QTP' s. I don' t think Kooks y-pipe is SS either though.
I' ve heard nothing but good things about fitment with the Supermaxx.
Old Jun 8, 2006 | 03:23 PM
Ravenous T\A's Avatar
I have a set of Dynatech Stepped Headers, not on yet but soon, they look awesome and thru Jegs they were like $479.99 Coated in & out. I have also heard nuthin but good things about them
Old Jun 8, 2006 | 03:24 PM
joecar's Avatar
I don't have a pic of them installed, yet... but this is what they look like, take a closer look at the Y-pipe.
Old Jun 8, 2006 | 03:31 PM
radz282003's Avatar
Those sure are pretty too. I like the idea of one-piece primaries, although, I am sure it doesn' t make a significant difference.
I do like the QTPs though. With the only change being the headers, and revised tune, going from the standard collector QTPs to their HVMCs, I gained from 5-10 RWHP. I say 5-10 because my max power showed 12 more horse, but, the tuner thought it may have been a spike. I DID get a verified 5 more horse though, and I think there was a little left, because intake temperatures were almost 50* higher with the HVMCs.
I know of a few people in my area that really like their Supermaxx. Either way, you can' t go wrong ;D
Old Jun 8, 2006 | 04:45 PM
natronathon's Avatar
****, get the QTP's. They are an awesome header. I love mine, and it isn't even a HVMC
Old Jun 8, 2006 | 07:11 PM
radz282003's Avatar
F' n A right!!!
Old Jun 8, 2006 | 07:16 PM
SS DNA's Avatar
Maybe If you bought the flowmaster merge collector and the maganflow 59950 Series cats, you could end up with a very nice Y pipe
Old Jun 9, 2006 | 10:19 AM
I have the Flowmaster merge collectors should be a very nice set-up when im done, i plan on later running a dual exhaust set-up oh and Screw CATS
Old Jun 9, 2006 | 03:16 PM
if you guys are really interested in this system you should check out my thread a while back. theres some really good pics of when i was installing them. heres the link.
https://ls1tech.com/forums/showthrea...tech+supermaxx
