Any way to fix broken ls6 intake
Old Mar 1, 2003 | 01:44 PM
theblur98ss's Avatar
Default Any way to fix broken ls6 intake
I have a broken ls6 intake that I was wondering if it could be fixed. There is a chip(hole) on the back side of it about 3/4" long. Just curious what, if anything, can be done with it.
Old Mar 2, 2003 | 05:37 AM
DaddySS's Avatar
Default Re: Any way to fix broken ls6 intake
I would think that if you got an autobody patch kit - fiberglass patch, and bondo, burnished the edges, then patched it, it would be fine. When the guys around here filled the "Corvette" on the fuel rail covers (basically the same material) with autobody filler, it seemed to bond and hold really well.
Old Mar 2, 2003 | 01:11 PM
CanuckSS's Avatar
What happened to the intake?
There are lots of epoxy's available that
may work?...JB Weld comes to mind.
Dave
Old Mar 2, 2003 | 01:57 PM
highgmc's Avatar
are you going back to ls6 rather than sheetmatal intake?
Old Mar 2, 2003 | 03:15 PM
This is the intake that UPS either played hockey with or drug behind their truck. It's a bad situation and I'm hoping I can find someone that wouldn't mind using a patched intake.
Old Mar 2, 2003 | 03:58 PM
Slick9.5's Avatar
i'd take a patched ls6 intake for $100. as long as it is fully sealed and works fine.
Old Mar 2, 2003 | 08:19 PM
TreeGreenZ's Avatar
hell if it is fixed and you would test it on "your" motor I would give ya 300 shipped <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 3, 2003 | 10:58 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Post up a pic Brad.
