Throttle cable and TB ??
thanks for the help any ideas are appretiated. thanks again Mike.
Did you use your stock cable cam and shaft assembly? The 98-99's have a different cam than the 00-02's.
The shaft/cam slides out and you slide the new one in and re-assemble. Use some blue loctite on the blade screws when you put it back together. You'll need some Torx head stuff to take it apart too. I got a little blue case from Advance Auto that was about $5 which has every freaking torx/allen/screw (philips/flat)/adapter you can want. I get a TREMENDOUS amount of use out of it.
