LS2 plugs wires better fit?
Old Jun 11, 2006 | 10:44 PM
jlashley2001ss's Avatar
Default LS2 plugs wires better fit?
Im wondering if the LS2 plugs wires are a better fit for longtube headers than stock LS1 wires? Would it make it easier to change out plugs with the LS2 wires? TIA guys
Old Jun 12, 2006 | 12:14 AM
TheBlurLS1's Avatar
That's what she said...
I like mine. A few of them kind of rub the headers on the little pull-off tabs but it doesnt do damage other than a little crusty spot. The wires are longer, so you can orient the coil boot to keep the main part of the plug end off of the header.
Plus I got them for $20.50 on eBay.
Old Jun 12, 2006 | 09:54 AM
GuitsBoy's Avatar
But can you get them in red?
Old Jun 12, 2006 | 10:35 AM
TheBlurLS1's Avatar
Mine are red.
Old Jun 12, 2006 | 10:54 AM
TheBlurLS1's Avatar
https://ls1tech.com/forums/showpost....5&postcount=11
Old Jun 12, 2006 | 12:39 PM
joelvette's Avatar
will they reach up to the truck coils. you need longer plug wires for them right?
Old Jan 2, 2007 | 06:50 PM
The Professor's Avatar
TTT. anyone else use ls2 wires?
Old Jan 2, 2007 | 07:01 PM
2002 SS #476's Avatar
Don't do it, they look like junk on the LS1/LS6. There to long and bend out to far, actually the LS2 wires are a worse fit for headers than the LS1 wires. I tried a set when I put my KOOK's on, took them back off and returned them. You can get the LS1/LS6 wires in red or the original color, they actually fit perfect with headers anyways.
Old Jan 2, 2007 | 07:11 PM
i only wanted them for the 90 degree bends. don't they help clear the header better?
Old Jan 2, 2007 | 07:25 PM
Not at all, wish I would have taken pictures so you could see. With them being longer, it actually makes them rest on the headers. I bought them for the same reason you wanted them. Once I tried some of them on, and saw the way they looked, I took them right back off. Use the stock ones and a set of cool socks (that set fits real nice).
Old Jan 2, 2007 | 07:54 PM
good look. i almost ordered some ls2 wires. i ordered cool socks instead. thanks!
Old Jan 2, 2007 | 08:56 PM
Long Beach's Avatar
Agreed, i did the same thing thinking that they would fit better with my kooks but they actually were worse. Spend a little extra money and get some msd wires. Or use the good old stock ones. Good luck
Old Jan 3, 2007 | 12:45 AM
greysteel_M6's Avatar
Being longer are they easier to put on?
Old Jan 3, 2007 | 02:16 AM
Long Beach's Avatar
like was said above that because of the angle they will touch the header more than the stock does. Im using a combination of both so that way no wires touch at all.
Old Sep 16, 2008 | 09:17 PM
Droptoplt1ta's Avatar
Can anyone else confirm that the LS2 wires are not good to use on a LS1 with headers?
I have the Ebay LT headers, and the front one on the pass side touches the header (stock wires)
Old Sep 24, 2008 | 09:33 AM
Come on, anyone else run these?
