Quick LS6 intake swap Q.
I'm considering installing mine today and wondering if I'll have enough daylight. Should I have a friend help out? Any additional tips&tricks? Thanks!
Also, Do I need an EGR block off plate to complete the install? I ordered supposedly "everything" I needed to do the install from ts&p. I'm still unsure of this situation.
Find the big *** black brake booster, which is behind the brake reservior, then follow that hose coming out it to the back of the manifold. Right before you get there you'll feel the oil pressure sending unit poking up with that hose running around it.
If you're deleting the EGR system, you'll need blockoff plates for the manifolds/headers, which I doubt the LS6 comes with from TSP.
What other mods does the car have?
Yes be careful of that sending unit, it is a $60 piece and it is not fun to break as i was replacing my Camshaft sensor and ended up breaking the oil pressure thing.
and I did disconect the brake booster hose and still broke it. Took me and a friend about 1.5-2 hours to get apart and took me about 1-1.5 hours to get back togethor alone going slow and checking everything the whole time
