ASP pulley question....
Old Mar 22, 2003 | 08:16 PM
Camaro SS 2002's Avatar
Default ASP pulley question....
Excuse my ignorance....when changing the alternator and crank pulleys, is this a mod that the computer must "re-learn" to obtain its full performance?
Old Mar 22, 2003 | 09:02 PM
Mike K.'s Avatar
Default Re: ASP pulley question....
This mod doesn't affect engine function air, exhaust etc so I do not thing that the computer will have to relearn this.
Old Mar 23, 2003 | 01:25 AM
DONAIMIAN's Avatar
correct me if im wrong, but dont the use of the alternator and the crank pully push the full charge mark up to like 950-1000rpm or so. Just a FYI for if you have a system
Old Mar 23, 2003 | 01:58 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by stang killer:
<strong> correct me if im wrong, but dont the use of the alternator and the crank pully push the full charge mark up to like 950-1000rpm or so. Just a FYI for if you have a system </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Im not quite understanding what you are saying. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
P.S. I have no stereo modifications.
Old Mar 23, 2003 | 02:03 AM
ULTIMATEORANGESS's Avatar
i was told with an ASP crank pulley you wont get a full charge till 900 RPMs.
Old Mar 23, 2003 | 02:08 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ULTIMATEORANGESS:
<strong> i was told with an ASP crank pulley you wont get a full charge till 900 RPMs. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I see in your sig that you have the ASP crank pulley, do you have the alternator pulley as well?
How do you like the ASP pulley? Also do you have an A4 or M6?
Old Mar 23, 2003 | 03:54 AM
JB98Z28's Avatar
I heard that the pulley systems contribute to knock retard? anybody able to confirm this?
Old Mar 23, 2003 | 04:16 AM
DaddySS's Avatar
if you have an automatic, you need to be aware of the fact that full charge will not occur at idle in drive, for M6 cars, this is not a problem.
I have not heard that pulleys will contribute to knock retard, unless you put them on wrong I suppose.
Old Mar 23, 2003 | 08:07 AM
Rob98Z28's Avatar
Everyone I talk to on the subject suggests to only use the ASP crank pulley and not to bother with changing the alternator pulley. Less complications apparently.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 23, 2003 | 09:53 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Camaro SS 2002:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ULTIMATEORANGESS:
How do you like the ASP pulley? Also do you have an A4 or M6? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i have an a4.i forgot to list it earlier. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> just crank only i have.i noticed the faster guys were using these pullies and its fairly cheap so i went with it.its a good mod imo.i had my idle turned up slightly when i had tuning done.it might need to be turned up more but it only drains alot with everything on at a standstill.definitely a worthwhile mod.
Old Mar 23, 2003 | 11:28 AM
JB98Z28's Avatar
Are there more powerful alternators available to off set the slower idle?
Old Mar 23, 2003 | 07:59 PM
CamaroSS_2002's Avatar
LOL, I saw the name and thought to myself WTF I didn't post this <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Mar 23, 2003 | 08:03 PM
last of the Z28's's Avatar
your steering problem probally has to do with your header install.....think about it.
Old Mar 24, 2003 | 12:27 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DaddySS:
<strong> if you have an automatic, you need to be aware of the fact that full charge will not occur at idle in drive, for M6 cars, this is not a problem.
I have not heard that pulleys will contribute to knock retard, unless you put them on wrong I suppose. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is what I have heard as well. Do you have the ASP alternator AND crank pulley? If so, any charging issues at all?
P.S. FWIW, I have an M6.
Old Mar 24, 2003 | 12:30 AM
Benjamin Russick's Avatar
I have the ASP installed with no comlaints. No alternator pulley, or noticeable knock retard. Good mod as far as I'm concerned!
Old Mar 24, 2003 | 12:34 AM
bo0oost's Avatar
After my ASP pulley install, my steering wheel has play in it, from stop and roll. It can move either way about 1/2" until it grabs, and the car starts to turn.
Anyone else like this?
We did it at the same time as headers, but we adjusted the steering rack properly.
