how to install a water temp gauge?
As for the temp guage, there's 2 places you can put the sending unit at. One is on the back of the passenger side head. This is where most put there's at. There's a plug by the #8 plug that you will need to take out. If you put the sending unit there, you'll need an adapter kit for the sending unit. Search for it, there's many links to buy the kit. The second place is behind the starter. Of course you'll have to drop the starter to get to it and I'm not too sure if you will need the adapter kit for this location.
Or there's one more route you can take, I've seen it done on one car so far. You can tap on the top of the water pump and stick the sending unit there. Either one is up to you.
I would suggest since you're doing a head swap soon, just to wait then. You will have easy access to the location by the #8 plug. It'll be easy to install the sending unit while the head is off the car.
One guy put his in line with the front coolant pipe, not sure how well it's working for him, but it was super easy.
Thanks
Adam
Thanks
Adam
Thanks
Adam
fittingsandadapters.com has steel adapters - much better than the brass adapters that are so easy to break.
Link: Adaptor (Jeg's Part # 105-2268)
I used brass fittings I got at the local hardware store. I got a 3/8" "T" fitting, used one port to put the sending unit in, and 2 3/8" barbed hose ends to connect to the hose coming from the crossover line going to the TB and radiator. You effectively do a TB bypass when doing this also, so you kill 2 birds with 1 stone. Mine is currently tucked under the bellows, out of sight. You just have to also drill and tap a hole to mount a ground wire to. A small self-tapping screw with a dab of teflon pipe sealant worked perfectly. Just wondering
I used brass fittings I got at the local hardware store. I got a 3/8" "T" fitting, used one port to put the sending unit in, and 2 3/8" barbed hose ends to connect to the hose coming from the crossover line going to the TB and radiator. You effectively do a TB bypass when doing this also, so you kill 2 birds with 1 stone. Mine is currently tucked under the bellows, out of sight. You just have to also drill and tap a hole to mount a ground wire to. A small self-tapping screw with a dab of teflon pipe sealant worked perfectly.I will post one when I install it. The adapter is going to be here on the second so it may be a little while.
i want to install my sending unit in the head....where can i buy the adapting kit?
