Anyone have problems installing the FTRA?
the instructions are not hard to follow. if you are refering to the number of steps and pages that they include, take in mind most of the steps are,
"Step 5. Remove the Air lid.....
Step8. Remove the Four bolts that hold the lower section of the air box."
I thought the little sticky foam pieces where junk, so i used duct tape to seal the whole thing up.
First: Step back from the car, crack a beer or two, and take a break. This step is important for most modding. Skipping it sometimes leads to broken parts and/or knuckles. Just don't get carried away, or else you'll be awfully dissapointed when you can't test drive your new mod cuz yer smashed.
Then: Go back to the topside and make sure everthing is properly aligned and pushed down. It's also possible that you did everything correctly, but the stackup of errors between Fast Toys' and GM's manufacturing of the pieces involved equals misalignment of holes. In that case, put some body weight into it until you can get the bolts through.
Paul
But, good luck with yours <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
