dyno's with filter and without
Post your dyno's with filter and without filter, cuz i wont to know what's the best thing for race,
Note: i have K&N filter, TB ported, SLP MAF, LS6 intake, LID, kit cam MMS, ASP.
Thanks
God saves US ARMY <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
Back long before I did my motor. I did back to back pulls on a DynoJet 248C
Pull 1 was with a K&N filter = 316rwhp
Pull 2 was with a paper Fram filter = 318rwhp
Torque was just the opposite. I don't remember the number, but the K&N put 2 more lbs-ft out over the regular paper Fram. The only difference in the runs was the 30 seconds it took to swap filters.
I don't think I never did a non-filter run.
Obvisouly it does not give you the 40% more power as K&N advertises (or whatever their claim is). They both made identical power numbers. I consider the 2rwhp and 2lbs-ft negligible as it could go either way and simple things such as heat soak and even test conditions could vary slightly. I'll sum it up by saying...they're even in terms of power.
The Advantage though to the K&N is it's cleanability and re-usability. Whereas the paper...we all know what happens to that when it gets dirty.
That's why I stick with my K&N...it's serviceability aspect.
they seem to refer to using a high-flow lid
and then they compare their lid & filter combo
against the stock lid & filter. All the gain
is in the lid.
You can replace a paper filter for like $3,
and you can do that about 15 times for the
price of a K&N. Mine's still clean-looking
at 8K miles, so I'll have to roll over 100K
(or take up driving on dirt roads) before
the K&N is any kind of money saver.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> posted June 11, 2002 07:47 PM
I saw a minimal difference between paper and
the Donaldson filter in my "Shop Vac Test".
That is, at whatever flow rate the shop vac
was capable of, [totally uncalibrated, but
relatively repeatable] These are the pressure
drops I recorded, in inches of water:
Lid, no filter: 0 - same as open shop vac port
Lid, Donaldson: 1/2"
Lid, Purolator: 3/4"
Lid, Fram: 7/8"
Lid, OEM: 7/8"
By comparison:
OEM Lid, open: 1-1/8""
MAF with screen: 2"
The Oiled membrane filters will be somewhere
between the paper filters, and nothing. Yeah,
you could gain a whole 1/2" H2O of pressure.
That's like, what, 0.02PSI of boost. Maybe the
intake flows twice as much as my shop vac. Call
it 0.04PSI. Our throttle area is < 2X as big.
On the supercharger price/performance scale,
you're looking at something like $300 per PSI
of boost.
So if the filter costs more than $12, it's more
expensive per lb of boost - incremental horse-
power - than a supercharger.
From what I read, each PSI of boost looks good
for maybe 30 HP. Sanity check this as 325HP stock
HP / 14.7 PSI = 22 HP/PSI.
So using the latter, the ultimate filter [zero
drop] would give you about 22HP/PSI*0.04PSI or
1HP over the better paper ones.
Woo-hoo! Ain't science fun?
I put the Donaldson in a box and run with the
Purolator since that last horsepower isn't
someting I use often and the filter's not
cheap [I dunno if I can even get a replacement]. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
IMO The K&N is not worth it. Having a lid that has smooth transitions into the MAF opening (to minimize flow separation as much as possible) is way more important than the flowrate through the filter. Fram gets my money.
just my .02 <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<strong>Also, a paper filter may not show much differences when new to a k&n, but after 10K on a paper try and compare to 10k on a k&n.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I dynoed with a dirty Fram filter (I forgot to replace it with a new one before dynoing). It had been in there for well over 10k miles. I took the filter out and made a pull with no filter and gained about 5.5rwhp (this was also on the 3rd pull which usually makes the most power anyway). If a dirty K&N flows more air than a dirty Fram, the amount of power difference still seems pretty minimal. Just some FYI. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
