Old 04-25-2016, 04:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
True Duals, questions answered here. Post YOUR information and pics too!
Old 08-14-2019, 08:25 AM
  #1361
Gripenfelter's Avatar
Originally Posted by blackandgold
Realized I haven't posted in this thread. I'm running Kooks 1 7/8" headers into their true dual system with dual (not quad) tips, it does in fact fit with the MWC FAB9 and watts link. It's loud, but I don't mind although since I'll be moving to a city with emissions testing next year I'm working with Kooks to get an x-pipe with their green cats I can bolt in easily.
Which Watts link do you have?
The following users liked this post:
Steven503 (01-27-2021)
Old 08-14-2019, 08:38 AM
  #1362
blackandgold's Avatar
It's the MWC one that mounts directly to their FAB9 rear axle housing.
Old 09-14-2019, 12:42 PM
  #1363
BluebirdLS's Avatar
Can you tell which cats those are in your photo. Also would you know if the 4th gen firebird is the same underneath as the camaro? I want to add some on mine.
thanks
Old 09-14-2019, 12:44 PM
  #1364
BluebirdLS's Avatar
My WS6 is lowered 1.5”. I'm running Speed Engineering True Duals. The bolts that come with the kit are absolutely useless. You can't get them tight enough without stripping them. If you leave them loose the pipes come apart. I lost a wideband O2 that way. I upgraded the bolts to stage 8 bolts and also welded a tag on each piece of pipe at the lips to keep them from moving.
It’s a heads and cam car with a 228/228 cam and trick flow heads. Idles a little high at 950 rpm. Needs some tuning. Video doesn't do it justice. It sounds amazing and I get compliments from everyone. Sounds very refined with the cats. It's still loud and will set car alarms off but doesn't have that ratchety straight pipe crackle.
I added the high flow cats to smoothen out the sound and also welded it up on the hangers to get extra clearance. Had to clearance the torque arm as well. No extra heat from cats.
https://youtu.be/qN0_mJv4qNM
can you tell me which cats those are and do you think they will work on a 2000 ws6? I have LT, x-pipe set up
Old 09-14-2019, 12:54 PM
  #1365
Magnaflow 3" high flow cats. All 4th gens are the same underneath. The only thing that would be different is aftermarket suspension parts.
Old 09-14-2019, 12:59 PM
  #1366
BluebirdLS's Avatar
I thought all the hi flo cats were rounded, yours looks more traditional in shape. I was hoping those may fit better. Any shop I go to, no one will put them on, saying not enough room.
Old 09-14-2019, 01:05 PM
  #1367
Local exhaust shop installs lots of these on Fbodies.
Old 09-14-2019, 01:58 PM
  #1368
BluebirdLS's Avatar
thanks, it looks like my set up has the pipes turned towards the x pipe closer to the headers leaving less room for cats. Sheesh, Not sure if a shop would run me some pipes moving my x pipe a little further down to get some cats in.
Old 03-31-2020, 11:35 PM
  #1369
chrysler kid's Avatar
True dual setup #4 for this car
Old 04-01-2020, 01:15 AM
  #1370
Received 3,085 Likes on 2,401 Posts
Why wrap the whole system? That system will be heat treated to death within 2 years. Wrapping serves no purpose.
Old 04-03-2020, 10:27 AM
  #1371
Reduce in cabin noise.
It made a big difference inside the car, I can actually have phone conversations and go through a drive through with the car running
Old 04-03-2020, 03:47 PM
  #1372
newby96's Avatar
Default My speed engineering true duals
I just installed se true duals. Love how it sounds.
Old 04-03-2020, 11:34 PM
  #1373
The SE TDs were a bit raspy to me so I added high flow cats to smoothen it out.
Old 05-04-2020, 05:06 PM
  #1374
Shinobi Adam's Avatar
I have been looking at trying to get a fully bolt on header and true dual combo that comes with cats and the only company I have found is Kooks. Any one know any others? I have to emission this car and like to do everything myself on my cars. No access to a welder.
Old 05-04-2020, 05:44 PM
  #1375
TheNutDriver's Avatar
No, as far as I know, Kooks are the only manufacturer who can supply an off the shelf catted True dual system.
its either spend the $$$$$ time or drop that “working myself” ethos just for one job.
Old 05-04-2020, 07:05 PM
  #1376
Fair enough. I guess I'll check my local shops for pricing or just start saving.
Old 11-02-2020, 04:12 PM
  #1377
Robert Zajkowski's Avatar
Man that looks Good.
Old 11-02-2020, 04:18 PM
  #1378
Nice Job on the Muffler system. I wish I had the desire to work on my own exhaust on My truck. So far i have a Cherry Bomb on my 5.2 dodge ram. But it sounds good to me.
Old 10-31-2021, 12:39 PM
  #1379
Racer-X-'s Avatar
I hope some folks who have done exhaust systems can give me an answer here.
We're doing a "true dual" system for one project that I'm working on. This one has some strange parameters/requirements.
The one thing I'm going to need that I haven't located/identified yet is the muffler(s). I think the optimum muffler for this one is going to be dual inlet, dual outlet, all in and out will need to be 2.5". I wish there was a FlowMaster Super 50 Series in that configuration, but they don't make it that way.
This one needs to be quiet (until the cutouts are opened), but preferably not loose (much) performance. I'm looking for something around the same sound level as a stock Cadillac CTS-V, or maybe even slightly quieter than that.
Does anyone have any recommendations/suggestions for this?
We also will be doing cutouts on this one, but piping the cutouts to two additional tips at the rear. The end result will have four tips, like a C7 or late C6 Corvette, with the muffled pipes in the outer positions, and the cutouts going to the center two pipes.
Old 10-31-2021, 02:26 PM
  #1380
There is a Flowmaster Series 50 dual-in dual-out 2.5" connections #8525554,lists for about $260. Moderate sound
Also there are 2 different Series 50 Big Block mufflers that have either 3" or 2-3/4" inlets that you can swell the pipes going into it to fit.
They are #530504 (3") and 527504 (2-3/4"). Both of these are quieter than the first one.
Quick Reply: True Duals, questions answered here. Post YOUR information and pics too!
