Is my catch can doing its job?
Old Jul 15, 2006 | 09:22 PM
FireSilverLullaby's Avatar
Default Is my catch can doing its job?
The lines going to and from the catch can were blue and now theirs oil coated on both of them. After half a tank of gas their was about 5 drops of oil in the catch can.
If theirs oil in the line going to the intake manifold does this mean that oil is still going into my intake manifold.
Their is a picture of the catch can on my cardomain, its the first pic. http://www.cardomain.com/ride/2301941
Would it be better if I put the tube coming from the pcv valve halfway down the catch can?
Old Jul 15, 2006 | 11:15 PM
BobbyWS6's Avatar
Pull hose off of throttle body from can. If you feel flow, then it is probably just fine. You may not have much blow by at all. Also, you can take off your throttle body and look inside your intake manifold with a flashlight. Look for thick oily coating (bad) or almost nothing (good). That simple.
Old Jul 16, 2006 | 12:12 AM
bene's Avatar
Trunion King
There shouldn't be any oil on the other hose, to make sure do what he suggested. I checked mine today and I noticed I'm still getting "little" oil in my intake. Looks like I'm goin' to !PCV on my car.
Old Jul 16, 2006 | 09:46 AM
Alright I might do that today, what would be the next thing to do if their is alot of oil in my intake? thanks
Old Jul 16, 2006 | 04:53 PM
Should I just switch to a breather?
Old Jul 16, 2006 | 06:29 PM
bene's Avatar
Trunion King
Its your last alternate to prevent oil in your intake. Metco sells a screw on breather or you can fab out of a breather/oil cap from autozone.
Old Jul 31, 2006 | 09:22 PM
Jayh's Avatar
what if you get oil in your intake....?.......Atleast it appears that I have...LINK...
https://ls1tech.com/forums/generation-iii-external-engine/551307-crao-coming-beneath-intake.html
Old Jul 31, 2006 | 09:39 PM
Jayh's Avatar
This is what I seen looking into my intake thru the throttle body.....
Old Jul 31, 2006 | 09:57 PM
bene's Avatar
Trunion King
Time to SEAFOAM that biotch, ASAP.
Old Jul 31, 2006 | 10:00 PM
bene's Avatar
Trunion King
While you're at it... you can port/polish that TB, do a bump stop mod, TB bypass. I'll show you what it'll looks like... I'm 15 min. away from LR.
Old Jul 31, 2006 | 10:03 PM
Jayh's Avatar
I started the Bump stop but changed my mind....Bypass is already done.....I dont even know what seafoam is......
Old Jul 31, 2006 | 10:11 PM
bene's Avatar
Trunion King
Its an intake manifold cleaner. Get rid of those oil build up you have in your intake.
Old Jul 31, 2006 | 10:12 PM
Jayh's Avatar
You think it screwed anything up in my fuel system?......a month or so ago I lost my gas pedal for about 5 secs....kind of felt like I had full choke on or something. Nothing ever since except getting less than 10 miles a gallon (somthing like that) and it aint my lead foot.
Old Jul 31, 2006 | 10:14 PM
bene's Avatar
Trunion King
Yeah, you probably have a good build up in your valves also... SEAFOAM will take care of those too.
Old Aug 2, 2006 | 06:07 PM
Alright I ported my tb today, so i took some quick shots of my intake manifold.
Its definitley still leaking oil into the intake. Could I just block off the hole where it goes into the intake manifold, and put a breather to cap the hose (the one coming from catch can to the intake manifold.
Old Aug 3, 2006 | 02:18 PM
any ideas?
Old Nov 4, 2006 | 11:12 PM
do you think a husky air compressor filter would work better, cause the catch can is working at all, theirs just a few drops in it after over 3,000 miles and theirs definitley oil in my intake.
Old Nov 5, 2006 | 04:18 AM
DemonSS's Avatar
Hey guys does this usally come from a car that is cammed? I just had a MS3 cam installed 3 weeks ago and noticed that my car smokes when idling.Not while driving down the road only when coming to a stop or like i said just letting it idle. What can i do about this, any ideas?
Old Nov 8, 2006 | 12:05 AM
Ripper415's Avatar
i clicked on your cardomain page but couldnt find a catch can pic, maybe that post from up top was a bit out of date....but check out my catch can setup on my cardomain page (its on the 2nd page about halfway down). after only about the first 500 miles a got a GOOD amount of oil in the husky can. i highly recommend it.
Old Dec 3, 2006 | 07:03 PM
yeah maybe ill sell mine, and convert to the husky.
