Header Confusion! Please Help!
Old Jul 30, 2006 | 03:10 PM
dubtheincredible's Avatar
From: Where the Navy sends me. I'm from and call Georgia my home though.
Question Header Confusion! Please Help!
Which Headers are best or does it matter?
I want to bolt up a set of headers to optimize the flow from new intake, but can't decide on which ones. Pacesetters are cheap, Hookers look the exact same but cost $300 more, Kooks are supposedly the best buy why? Are the tuned headers from SLP worth the money? I plan on putting a dump on the Y-pipe and looking to build a 400hp daily driver not a race car. Any and all help would be appreciated!
Old Jul 30, 2006 | 03:13 PM
RrCoX22's Avatar
just go with pacesetter if your not looking for stainless....
all headers vary from 1~10rwhp difference from each other
supposeably the the QTP HVMC headers are the best flowing (yet expensive ) out there right now
Old Jul 30, 2006 | 03:18 PM
HeapaShifter's Avatar
I'd say stainless steel headers are the best. (Kooks, QTP, SW)
Old Jul 30, 2006 | 06:06 PM
stevensLS1's Avatar
get stainless. they will out last your car. if you get slp long tubes everyone gets to kick you in the *****! they have the absolute worst clearance ever! so go with kooks, or QTP.
Old Jul 30, 2006 | 06:30 PM
Z28_DAD's Avatar
i like my edelbrocks. they are not too expencive
Old Jul 30, 2006 | 06:42 PM
RrCoX22's Avatar
Originally Posted by Z28_DAD
expencive
expensive
...sorry i just had to do it
Old Jul 30, 2006 | 06:45 PM
Z28_DAD's Avatar
Originally Posted by RrCoX22
expensive
Old Jul 30, 2006 | 07:20 PM
Camaros710102's Avatar
I went with ceramic Hooker LT's and they fit and perform great.
Old Jul 30, 2006 | 08:35 PM
Smokinstorm's Avatar
Old Drag Racer
x2...
Old Aug 3, 2006 | 04:36 PM
Thumbs up
Thanks for the help guys! I forgot to ask... which style should I go with? offroad, no egr, or emisions compatable...yeah right! but seriously strictly offroad headers or should I keep o2 sensors? Do the simulators really work?
Old Aug 3, 2006 | 05:49 PM
blkbird's Avatar
Pacesetters in my book....
Old Aug 3, 2006 | 07:15 PM
Order 66's Avatar
QTP HVMC tops in quailty and performance. Get the race style version and get rid of your air/egr crap.
Old Aug 3, 2006 | 08:05 PM
Weezzer's Avatar
I purchased the air emissions compliant QTP headers for my '02 bird. My passenger’s side header appears to be top notch quality. The driver's side looks like the resident drunk/crack ***** made it. The HVMC was dented twice near the merge collector which caused the aft end of the HVMC to be severely egged shaped. I took pictures of this and sent it to QTP and the response was : “It appears to be as it should be". On closer inspection the air fitting wasn't drilled thru the primary. I had to take a pencil grinder to remove a large piece of welding slag or other debris that couldn't be drilled thru because it was so hard. I took care of that and drilled it out to size. I had major over-weld in the I.D. of all four primary tube collectors (at the header/engine interface) and had to grind it out.
Now the problem I have is the header interface flange wasn't milled all the way across and the far outside bolt "ears" are not flat with the mounting surface and I fear if it isn't milled flat that after awhile the flange will bend/warp and result in an exhaust leak. QTP seems to only stand behind their product if there is no problem.
I am a very unhappy customer, needless to say.
I have to say I don't believe I'll ever buy anything from QTP again.
