question about your !pcv (people runnin breathers)
just deleted the pcv off of two cars today, left the line connecting the two valve covers. Just curious if you guys that have done this have had issues with smoke coming out of your breather (not alot) just a tiny steady stream of barely noticable smoke (oil vapor) Both cars do the same thing, one has a cam and one does not
Originally Posted by ls1wfo
System is set up as a closed system. You will now probably notice a 2 to 3 MPG drop in gas mileage, with no gain in HP or ET . Also increased oil consumption. Take it or leave it.
Increased oil consumption with a breather? That's new to me!
I run a breather now and it puffs out some smoke too, nothing to worry about. Make sure you change your oil every 3k on the dot if you're running a breather.
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I also don't understand how you're going to lose fuel economy by switching to breathers, all the PCV does is take the crankcase vapors out of the engine and recirculate them to burn during the combustion cycle. So unless oil vapors have some kind of magical properties that make them burn like rocket fuel, I don't see how there would be a difference in fuel economy
i deleted min about 3000 miles ago, i noticed NO decrease in MPG. still right aroudn 18-19mpg. My car still smokes out the exhuast though...pretty bad. I will drive it untill it breaks i guess.
What this person just said is 100% crap. You will not see a decrease in gas mileage, you will not see any gain or loss of HP, and you will see reduced oil consumption.
This guy needs to put the crack pipe down.
I have eliminated my breathers. No problems, I dont see how it would affect gas mileage. I drilled a hole in a oil cap and slapped a breather in there and put a breather on the end of my pcv line like 12 inches of plastic tubing is all it is. I would recommend this over an oil catch can any day and esp spending money on an ls6 conversion (valley).
