Any One From New Jersey That Would Be Willing To Help Get A Broken Header Bolt Out
Is there anyone from jersey that would help me get this bolt out that has done it before this install went soo smooth until we used the torque wrench with the stock bolts. Torque wrench did not click therefore i just kept going until i heard the click of the now broken bolt...... PLEASE HELP the abs module is out the coil packs are off and the header is also off. I would really appreciate if anyone would just give me an extra hand.. Thanks all
Buy this tool from McMaster-Carr. (404) 629-6500
1/2" Square-Drive Stud Extractor
The knurled bottom wheel on this simple tool lets you tightly grip studs and bolt ends. Removes 1/4" to 3/4" size studs. A standard 1/2" square-drive ratchet wrench (not included) drives the extractor. Use on right-hand threads. Made of steel. 2537A11 Each $26.54
Originally Posted by thekidran
Just trying to figure out how this thing actually works
Then you have two different sizes depending on the diameter of the broken stud. You slip it through the smallest hole and that knurled wheel bites into the broken stud when you turn it with a ratchet.
I've gotten out some large, siezed studs before using one of those. As long as there's about half inch or more of stud sticking out of the head, that tool will turn it loose. ~Joshua
There is the problem it is flush with the head this really sucks
You have to drill it dead center and use an "easy out." I doubt you'll get a drill angled correctly in the engine bay.
You'll probably have to remove the head. Thought about doing a heads/cam install? Now might be a good time.
The clearance is no problem i have been drilling all day with a dremel and i am getting no ware i am using a cobolt drill bit and i am only drilled in the bot about an 1/8 to a 1/4 inch which is not enough for the easy out........ i even drilled a hole in the fender well to see if we could get a straighter shot. If there is anyone out there who is willing to help me pull this head i really do not mind pulling it but i have noooo clue how to do this thats why i would need the help thanks for all the posts guys.......
