LTS and TDS + C02
Old Aug 28, 2006 | 08:01 PM
blackbird-TA's Avatar
Default LTS and TDS + C02
just slapd on my LTS and TDS no cats on a bout a few weeks a go and the C02 from the car is to much to handal all you guys that run TDs with no cats have this problem with real bad gas fumes getting in car and on you.. and smelling like gas i mean after 30/ 1hour of just driving my car i cant take it no more its like i want to pass out behind the wheel. is all TDS like this???
Old Aug 28, 2006 | 10:34 PM
bene's Avatar
Trunion King
I'm guessing you have the turn downs? Sounds like you're running rich.
Old Aug 28, 2006 | 11:02 PM
JEB Garner's Avatar
Run your duals over the axle and out the rear from beneath the bumper in the stock location. That will stop that exhaust smell inside the car as well as that roar and drone that goes along with dual that dump under the car. With your duals going over the axle and out the rear, you will probably enjoy your dual exhaust system.
Old Aug 29, 2006 | 01:35 AM
is that a bad thing running rich??? it is a gmmg blackbird WS6 with custom gmmg tunning for the mods it came with only thing i change was i add LT'S and tsp TD's if i dont get it retuned will it screw my motor up???????
Old Aug 29, 2006 | 07:31 AM
bene's Avatar
Trunion King
It's better to run rich (safe) than lean(holes in piston) but you'll lose HP rich.
Old Aug 29, 2006 | 08:53 AM
jmm98LS1's Avatar
Longtubes move your front o2 sensors further downstream in the exhaust system. The factory o2's have a hard time staying hot after the move, making them inaccurate. They are reading a false lean condition and are dumping fuel, causing you to run rich. You aren't hurting anything by any means, but you should have your car tuned for the LT's. If you plan on any other future mods (heads, cam etc) just wait on the tune until you add the bigger mods.
Old Aug 29, 2006 | 10:15 AM
lastcall190's Avatar
I notice it somewhat, I wouldn't say it's unbearable... but I've had !cats on damn near every car I've owned, maybe my body is fucked up Running rich is good TO A POINT, too rich and you'll wash the cylinders, which is rather unpleasant. Get a tune, you should notice improvements!
Also, what mods did it originally come with? Stock tuning will turn a little richer with LTs... I'd imagine that the tune, no matter what mods came with it, was just a little leaner across the board, making the impact of LTs somewhat less. I'd say you're safe (only one way to find out tho IMO, get 'er to a dyno).
-J
Old Aug 29, 2006 | 11:07 AM
jimmyblue's Avatar
Moderator
CO2 output is the same pretty much, whether you
have cats or not. CO2 and H2O are all that's
"supposed" to come out. What stings your nose
is mostly the nitrogen oxides and what stank, is
the hydrocarbons.
Dumping out the back is like pissing in the shower.
Dumping under the car is like pissing in the bathtub.
Old Aug 29, 2006 | 12:22 PM
ryanfx's Avatar
Old Aug 29, 2006 | 12:44 PM
Old Sep 1, 2006 | 04:37 AM
yeah think im gonna get my **** tuned soon but the only thing that bus me is that its a blackbird WS6 nd olready ben tuned for these mods
373 gears
gmmg catback
p/p manafolds somthing like a shorty header i was told???
under drive pulley
mas air meter
whisper lid
180 d stat
k&n
now if i get it retuned will it stop the c02 from being so!!! bad in side the care imean after 30/ 40 mins i want to pass out no joke!!
Old Sep 1, 2006 | 09:42 AM
sickws698's Avatar
if you dumb them out the back u shuldnt have a smell problem
