new ls6 intakes
Old Sep 4, 2006 | 10:39 AM
bad6as's Avatar
Default new ls6 intakes
slp has them with the intake with the plugs and crossovers
and then gmpartsdirect or fried beans has the intake but it comes with a bunch of seals.
i know i need the manifold, cross overs and plugs but i sasent sure about the seals.
wheres teh best blace to but the KIT so all i need to do is buy it from one plce and i get the parts i need all in one box.
Old Sep 4, 2006 | 12:32 PM
Shallow Bay's Avatar
TTT... I would also like to know because I will be purchasing an LS6 intake soon and have the same question.
Old Sep 4, 2006 | 01:23 PM
HeapaShifter's Avatar
The "bunch of seals" that it takes about are the port seals for where the intake connects to the heads. It might be the throttle body seal too.
I'm not sure on prices, but they are probably all close and all have all the parts needed so just take your pick.
I bought my LS6 intake used for a good price and then bought two crossover pipes from a chevy dealer. Putting a crossover pipe on the rear too is a good idea because it will help the #7 cylinder stay cooler. #7 is the most prone to detonation. It's an old road racing trick. Well, I guess not that old.
Old Sep 4, 2006 | 03:23 PM
bad6as's Avatar
so the seals off my 98 intake would be ok to cross over to the ls6 im
Old Sep 4, 2006 | 03:52 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Pick up a used one and just get the LS6 coolant portion at the dealership.
Old Sep 4, 2006 | 05:10 PM
The intake manifold kit I'm looking at includes the intake manifold, intake seal, intake manifold gasket kit, throttle body seal, map sensor, and map sensor seal. This kit is priced at $438.29 and I'm wondering if it sounds like a good deal?
When you put the crossover pipe on the rear, did you block off the unnecessary rubber line like they did on ls1howto or did you use a different method?
Old Sep 5, 2006 | 07:43 PM
bad6as's Avatar
any more info on whos kit comes with the most?
Old Sep 5, 2006 | 09:42 PM
Seems like a good price for new. Back when I was pricing them out they all came out close to $500. I'd recommend getting a used one though. In just as good condition, but cheaper.
No. I ran a hose up to the front. Here's a picture I drew for someone else asking another time.
Old Sep 5, 2006 | 11:09 PM
Thanks for the picture and that's a really good idea. Do you have any actual pictures of your setup? What size hose and t-fitting did you use? I was never a big fan of blocking off the rear coolant pipe and I'm thinking of trying this if you don't mind.
Old Sep 5, 2006 | 11:10 PM
MiaSSmaro98's Avatar
the only thing is if the rear croosover clamp gets loose then the hose will leak, will u have to remove the manifold to get to it
Old Sep 6, 2006 | 06:31 AM
FirehawkNS's Avatar
I did my LS6 swap this past Sunday and did what someone suggested on here, which was to dremal some ridges down from the intake so the stock 98-00 lines would fit. Seems like it worked great and didn't cost me a thing in pipes.
Old Sep 6, 2006 | 01:43 PM
thats good to hear
