FAST intake warning
Old Oct 5, 2006 | 09:36 PM
  #41
HEMIETR's Avatar
The worst thing about it is that I knew it. I should have just finished it the first night, it would have never happened. When your pressed for time, sometime you do stupid things. Oh well, its just another $400.00 ):
Old Oct 5, 2006 | 09:40 PM
  #42
KRAZY K 2000 TA's Avatar
and i thought it was my tune pissed about the no instructions thing
never had any sucks glad i havent ruined my car i was giving up onmy idle tune
Old Dec 9, 2006 | 01:35 AM
  #43
99WS7's Avatar
can somone give me a link to get these screws?
Old Dec 9, 2006 | 07:27 AM
  #44
STRIPSTAR's Avatar
Originally Posted by Z'mnypit
Pulled my intake off after I got off work and sure enough, every bolt on the valley cover has made dents/indentions in the bottom of my intake. None seemed to be cracked but im sure beings they were putting the intake in an uneven position that maybe thats why im sucking air from somewhere. Ill know tommorow morning if it is or not. Luckly I still had the bag of bolts it cam with....
I bet it didnt seal the intake port. Your probably fine. You guys didnt notice that it doesnt sit flat with the old valley bolts?
Old Dec 9, 2006 | 07:49 AM
  #45
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
lol at you guys for not knowing the valley cover bolts needed to be replaced. .... I did the same thing first time also. It was a total beatdown.
Old Dec 9, 2006 | 07:50 AM
  #46
ЯєŧąяĐ Єl¡m¡иąŧøя ™
you will be ok. Just a Vac leak.
Old Dec 9, 2006 | 07:51 AM
  #47
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I still have my bag of bolts. I just ground down the stock valley cover bolts..
Old Feb 13, 2007 | 09:50 PM
  #48
tamikews6's Avatar
http://www.compperformancegroupstore.../merchant.mvc?
Here is the link for the bolts. Does anybody know if they are reuseable?
Old Feb 13, 2007 | 10:10 PM
  #49
ls2 bait's Avatar
whoever restarted this thread i love u. i bought an intake used and it didnt come with any bolts! i would have bolted that damn thing on and ruined it!
Old Feb 13, 2007 | 10:12 PM
  #50
ls2 bait's Avatar
of course now i have to locate the bolts. didnt see them in the link above. would ones from say lowes work as long ans they are the same length/ thread or do they need to be shorter than that even?
Old Feb 13, 2007 | 10:13 PM
  #51
dpw41285's Avatar
its been two mon since the last past and just saved you a huge headache
Old Feb 14, 2007 | 07:38 AM
  #52
LS1Formulation's Avatar
You need to look harder: http://www.compperformancegroupstore...egory_Code=LSX
Old Feb 14, 2007 | 08:01 AM
  #53
stangbangin69's Avatar
just grind down the ole stocker bolts... cheaper and no wait!
Old Feb 21, 2007 | 02:11 AM
  #54
99Daytona500's Avatar
For those folks who may not have easy access to a grinder... There has got to be a cheaper place to get those bolts. $27...That's crazy! They might be available at some sort of specialty shop if not at Home Depot. I just got a used manifold but am still overseas so I can't exactly just go out and look, anyone find any lately?
Old Feb 21, 2007 | 10:49 AM
  #55
Arcolog2's Avatar
WOW lol, sad to say add another to the list.
I read directions usually, but I guess I only wanted to know the torque value of the main bolts lol.
Guess I'll pull it off and check since my car is down anyways!
Hope I still have that hardware!
Old Feb 21, 2007 | 11:38 AM
  #56
Brasil's Avatar
Does this issue also apply when installing the FAST 90 on a LS2 C6 Corvette? I am in the process of having mine ported, and would like to know before re-installing. I purchased the MAP relocation kit, C6 firewall kit, and LS2 fuel rail adapter kit, because the FAST 90 was not made to be a direct bolt-on for my car.
Old Feb 21, 2007 | 01:17 PM
  #57
mushroom281's Avatar
does anybody know the size of these bolts
Old Feb 21, 2007 | 05:21 PM
  #58
Brasil's Avatar
Can anyone answer?
Old Feb 21, 2007 | 06:04 PM
  #59
SiL3NtXWS6's Avatar
27$ isn't that bad actually. I bought 10 bolts from lowes for 30 something $ when i lost all my tranny bolts.. Metric bolts are not cheap.
Pay up.
Old Feb 21, 2007 | 08:27 PM
  #60
Brasil's Avatar
TTTTTTT
