FAST intake warning
Old Feb 22, 2007 | 12:42 AM
  #61
99Daytona500's Avatar
Originally Posted by SiL3NtXWS6
27$ isn't that bad actually. I bought 10 bolts from lowes for 30 something $ when i lost all my tranny bolts.. Metric bolts are not cheap.
Pay up.
The hardware kit that comes with the manifold is a rust magnet, if it were stainless hardware it would be a different story. I would like to find something that won't rust within a month.
Old Feb 22, 2007 | 12:49 AM
  #62
Originally Posted by mushroom281
does anybody know the size of these bolts
From the manual "10 M8 x 30mm Button Head Cap Screws (Replacement OEM valley plate bolts)"
Does this issue also apply when installing the FAST 90 on a LS2 C6 Corvette? I am in the process of having mine ported, and would like to know before re-installing. I purchased the MAP relocation kit, C6 firewall kit, and LS2 fuel rail adapter kit, because the FAST 90 was not made to be a direct bolt-on for my car.
Look at or research the valley cover from GM, if the bolts aren't rounded and low profile from the factory then it applies to you as well. Sorry I can't be of more help, don't have an LS2 around.
Old Feb 22, 2007 | 03:25 AM
  #63
Brasil's Avatar
I will check, mayybe it does apply to the LS2, because I noticed two foam pieces at the bottom of the LS2 manifold, when I removed it. Maybe they are there on the stock piece to clear the bolts.
Old Feb 22, 2007 | 07:31 AM
  #64
mushroom281's Avatar
i found my bolts but i have a question i did hear a pop when i put mine on but it idles fine and my scanmaster shows that my IAC is working so if i had put a hole in it wouldn't my IAC readings be 0 and shitty idle?
