LT Install HELP Hookers wont clear!!! Tips?
and drivers side keeps hanging up on the two bolts above the oil filter. Do I need to dent them to get them to fit? The bottom of the tire is at my knee so I think I have enough clearence. I already pulled the steering linkage,coil packs, plugs and wires? Any help would be appreciated!!! 1st get the car high as hell i mean high!
2nd on the driver side we had to take out the steering knuckle 2 bolts one on top one on bottom
3rd we removed oil filter and the breather tube about it with the 2 10mm bolts holding it in.
as far as the passenger it slid right in for use. also try removing the spark plugs that may help ya out as well.
good luck
What are you using to get the car so high? The kmember is at such an angle that the jack slides along the kmember some times while trying to get it higher, makes it seem like the cars gonna fall right off
As far as drivers side linkage is out as well as the lame heat shied. The headers have a unique twist that prevents them form clearing the oil breather above the oil filter, I think I'll go ahead and pull it out tommorow after class
It was a bitch to get them in, but when you do it one time, it gets very easy.
