Just did the Bumpstop mod
Old Sep 15, 2006 | 07:01 PM
WhiteStripes's Avatar
Default Just did the Bumpstop mod
Whew, that was a lot of grinding. Haven't driven it yet, but just wanted to say that you shouldn't use the stone type grinders but instead, one of these .
Old Sep 15, 2006 | 07:14 PM
Test Drive, concludes A+ for a free mod. Big time throttle response increase.
Old Sep 15, 2006 | 10:12 PM
TORCHD 02 TA's Avatar
i really did not notice much after the bump stop mod
Old Sep 15, 2006 | 10:13 PM
Revelation Z28's Avatar
how would you get a better throttle response for the BSM?
Old Sep 15, 2006 | 10:23 PM
the BSM allows the TB to open to almost 90* providng that when you are doing you do not go over 4.71V..
Old Sep 15, 2006 | 10:28 PM
Formula_X's Avatar
I went to do that mod a while ago.. but when I looked for this bumpstop, I realized that I didn't have a bumpstop, theres nothing blocking the TB cable shaft at all in my car, it opens 90* stock.
Old Sep 15, 2006 | 11:05 PM
oooooooohhh
i thought you meant the rear bumpstops
Old Sep 16, 2006 | 07:57 AM
shouldaboughttheZ's Avatar
now you need to make sure you are getting it fully opened.
Pop the hood and have some press the gas pedal to the floor while your looking at the TB. Make sure the car is off too. If it is not hitting the bump stop, your carpet behind the pedal is in the way.
Old Sep 16, 2006 | 08:11 AM
i dont know if you are talking to me. but this is what i did. stock was 4.43V. grinded it to 4.67V then i had a friend go to the car floor it and it read 4.67V. but i never really felt a different in throttle response :whoknows:
Old Sep 16, 2006 | 09:13 AM
TLUZLS1's Avatar
I grinded mine down to i think 4.65 but when the pedal is slammed to the floor it only opens to 4.58...my carpet got in the way
Old Sep 16, 2006 | 09:22 AM
start grinding again.. or take up the slack in the gas pedal
Old Sep 16, 2006 | 10:43 AM
is there an adjustment to adjust the pedal cable?
Old Sep 16, 2006 | 11:16 AM
i personnly did not have to adjsut the cable and i dont think that the seach feature works anymore.. jsut make a thread about it
Old Sep 16, 2006 | 12:28 PM
Smokin87TA's Avatar
Restricted User
Yea there is an adjustment, well kind of, just add a zip tie or two on the cable after it crosses through the pedal, so it will take up the slack. This way you can get WOT without it really getting close to the carpet. Just make sure you dont pull it far enough where it opens the blades at idle.
Old Sep 16, 2006 | 01:04 PM
Bad Blu Formula's Avatar
Throttle response is not going to change with the BSM. All you're going to get is more flow at WOT, not anywhere else.
Old Sep 18, 2006 | 09:20 AM
DBUS6's Avatar
Just did my BSM and it wasn't the carpet that restricted mine it was that TCS/cruise control loop behind the battery/on fender well that kept it from making my mod @ 4.65v. Take off cover and twist it by hand and you'll see. So I disconnected my throttle cable at t-body and wound it up 2-3 turns to "shink" the cable. Idle will adjust itself. And yes I can feel SOP diff.
Old Oct 18, 2006 | 04:00 PM
98 Raptor TA's Avatar
i've heard you have to disconnect something (like the TPS) before you grind the bumpstop and then plug it back in, is that true or do you just leave everything plugged up?
Old Oct 18, 2006 | 04:03 PM
brad8266's Avatar
I was just gonna say that.
Old Oct 18, 2006 | 05:44 PM
Shallow Bay's Avatar
When I did mine, I left everything plugged in. I see no reason why you would have to disconnect anything. Below is a link to an excellent write-up on the bumpstop mod.
https://ls1tech.com/forums/generation-iii-external-engine/420817-bumpstop-mod-my-first-try-writing-install.html
Old Oct 18, 2006 | 05:54 PM
RA4926's Avatar
yes you do i can see it in your cardomain underhood pics
